Ethan_Wang
Oct 10, 2022 6:43 PM UTC
Change the order of exposed nested instances
It doesn’t look like there’s an obvious way to change the order of exposed nested instances. Right now the order seems to be based on reverse layer order. It’d be great if the order can be manually adjusted.
Screen Shot 2022-10-10 at 11.44.08 AM
Joerian_Lazaroms
Sep 27, 2024 6:44 AM UTC
+100 Keep this alive. I would love this!
Maria_Libelt
Oct 4, 2024 1:40 PM UTC
Yes please, I need this 🙏 We use global layout component and instance slot component within it for content. This nested component is changed the most often but it is so hard to find among the nested instances because of the ordering. 😦
nigel.sham
Oct 29, 2024 2:04 PM UTC
Is this getting fixed or what? 2 years in and still no signs of this issue being fixed.
Inani_Sara
Nov 1, 2024 3:57 PM UTC
Need this please!!! +100
Jessie_Diao1
Nov 11, 2024 4:10 AM UTC
Need this, please +1024
Bjorn_Jarnankar
Nov 21, 2024 5:16 PM UTC
Yeah, +1 000 000. Should be easy enough to implement too and would help a ton.
Karolina_Mrozowska
Dec 9, 2024 5:31 PM UTC
I’d be so great to be able to reorder nested instances!
Mila_G
Dec 12, 2024 3:21 PM UTC
This is what should’ve been worked on instead of those superficial AI features…
If its too difficult/time consuming to implement the reordering of props, at least give us a ‘spotlight’ modal so we can highlight buried nested components. This way they will at least stand out when scrolling through a complex component with lots of properties.
ScottDaniels
Dec 17, 2024 4:11 PM UTC
+∞ Being able to organize our components by re-ordering Properties with Nested Instances would make the instances more useable and would cut down on restructuring our components over and over to get the order right.
Nick89
Mar 4, 2025 10:39 AM UTC
Yes, I am also shocked that this feature is not in yet, I have a very important variable that needs to be on top (even above the "normal" properties) but now it always remains at the bottom. Please make it possible for us to re-order and mix these up (regular and nested properties).
I'd also love to rename the nested instances labels (sometimes we hide the nested components by using a period in front of the name, but this makes the properties panel look messy, or is there some workaround for that which I've missed?
