GrandPM
Jun 8, 2023 11:51 AM UTC
Change default canvas stacking in auto layout
I am using auto layout a lot in my projects and think it is awesome. However, there is one small issue that annoys me a lot. The default setting for canvas stacking is always “Last on top”, which is usually not what I want. For instance when switching state of a dropdown in a layout, the dropdown list will appear below the content that is underneath it (at least in my case where the list is using absolute position). With lots of nested auto layouts, things quickly become a mess if you forgot to change this when you created the auto layout. I would suggest either of these solutions:
  • Change default to “First on top”.
  • Make the default setting optional
  • Remember the last used setting (like the animation properties work)
LaoluRG
May 27, 2025 6:50 AM UTC
Hi ​@figma_admin 💁🏾
Dan_Macmahon
Jul 23, 2025 5:26 AM UTC
Please. It’s just confusing and such a hidden setting.
Nesign
Jul 23, 2025 7:34 AM UTC
totally agree with this
JD15
Jul 24, 2025 10:37 AM UTC
Absolutely. I assume it’s the Figma team trying to reestablish a new way of thinking of layers.
Years of using layer-based design software has taught us that the higher the layer in the list, the higher it’s position in stacking index. Not sure why they’d fight it!
Abhishek Vahalkar
Aug 3, 2025 3:00 PM UTC
Please @Figma this is very much needed, I am glad someone pointed it out… It is very unintuitive, please fix it ASAP.
kkohl
Aug 14, 2025 7:13 PM UTC
Is there an update on this? Maybe a global setting or something?
While I do use "last on top", "first on top" is way more common. It’s pretty annoying having to change it manually every single time.
Also, it leads to mistakes in designs because honestly, when you're in a rush, it's easy to forget to switch the setting…
Isaac_Gabriel1
Nov 14, 2025 10:51 AM UTC
Yes! Please! Such a  unnecessary nitpicky thing to change just for the sake of being cool…
In the meantime, you can set all your objects to ‘first on top’ at the same time, saves a ton of time. Also elements set to ’first on top’ will carry that setting to all copies, saving even more time.
Time that wouldn't need to be saved in the first place, let's be honest.
X5-产品-Harrid
Dec 4, 2025 6:40 AM UTC
I was also very confused, then I searched and discovered all of you who have the same need.
stanley14
Dec 30, 2025 6:41 AM UTC
10 months time, Figma team is still ignoring us~
Please treat it as a global preference, it makes so much sense to let user make decision.
Josh_Newday
Jan 6, 2026 10:33 AM UTC
Additional frustration:
Outside of Autolayouts, using the ] shortcut you can move things up in the layer order, putting them on top/in front  of the items below it in layer order.
But within in autolayouts, whilst using the ] shortcut still moves them up in the layer order, adding Ctrl-] shortcut to put them straight to the front jumps them all the way to the bottom of the stack. It seems counter intuitive, hugely inconsistent and needlessly confusing.
