DhiaB
Jun 27, 2025 9:25 AM UTC
can we copy design from figma make to the main design figma file ??
Is it possible the prompt result from figma make design wise to be copied in the main design file i’m not seeing any button that allows me to do that
Valeri Ivanov
Jun 27, 2025 10:25 AM UTC
Figma usually allows copy-paste between different files - I regularly paste from FigJam to Figma Design, so I don’t imagine it being a lot different with Figma Make.
Are you able to copy and paste into the same file? Try it as a test.
If your can, then try to just copy your content and paste it into the desired destination.
Hope this helps.
DhiaB
DhiaBAuthor
Jun 27, 2025 10:32 AM UTC
I’ve contacted the support for the moment they allow only to copy the code, not the other way around, but i see it as a needed feature since you can use it to generate a specific comp.
Anjou
Aug 25, 2025 1:09 PM UTC
Yeah, it creates good designs
It would be super useful if they allow to copy generated designs
azad karimyan
Apr 18, 2026 3:59 AM UTC
isn’t this the thing you want apparently they have added it.
https://help.figma.com/hc/en-us/articles/35060759685015-Copy-a-Figma-Make-preview-as-design-layers#:~:text=Instead%20of%20sharing%20screenshots%20or,all%20your%20familiar%20design%20tools.
