Auto Layout shortcuts
  • February 17, 2021
  • 22 replies
  • 2094 views
Dmeetry
new auto layout is awesome. But not having shortcut for it setting make me sad.
really miss shortcut for direction, aligment and padding and resizing option
Please make it
kenneth1
  • April 24, 2021
Same issue here, please Figma fix this issue 🥺
Apple
  • May 6, 2021
Are there any updates or plugins for this?
  • Often I am creating auto layout groups with the full width, space between settings, and centered vertically. I would love for there to be a keyboard shortcut for these so I can do everything from grouping to autolayout to arranging without having to use the sidebar
Maty
  • Active Member
  • December 8, 2021
+1
Shortcuts are key to a great workflow (Pun intended)
Alireza_Rahmani
A lot of designers use keyboard shortcuts to increase their designing speed. but when it comes to auto layout the speed decreases significantly since you have to use your mouse.
It would be awesome if there was shortcuts for auto layout Direction, Alignment and Resizing Options.
Currently free Alignment shortcuts are Alt+WASD, I Suggest Alt+Shift+WASD for auto layout alignment
what are other ideas?
FlorianF
  • April 10, 2022
I’d love to see shortcuts for hugging contents, filling container, etc. And: once we have those, give us another trigger that will propagate something like “fill container” all the way down (or up in upside down figma land?) to all the frames from the selected one. Fiddling with these controls is one of the slowest aspects of Figma. 😉
Alireza_Rahmani
BTW I found a simple shortcut (not keyboard) for content hug it may be useful,
⚡ you can double-click on border of a fixed auto-layout to set the resizing to Hug Content.
Krunal_Patel
Thanks, @Alireza_Rahmani for sharing this. I am shifted to Figma from XD recently and sometimes auto-layout give me so much struggle. But this small trick will save lots of time in the future 🤗 👏
Kieron
  • April 6, 2023
Shortcut for changing the direction of the auto layout between vertical and horizontal would be awesome
If you double, click on an auto layout element it will switch to hug the content of that element if you double click while holding option it will make that element switch to fill the auto layout container.
Maty
  • Active Member
  • August 18, 2023
Yeah i use that a lot, but it does not work if you select multiple frames…
  • April 15, 2024
Why don’t we have shortcuts for auto layout directions yet?
It’s been years since this thread started.
  • May 29, 2024
+1 to this. Recently received my Work Louder x Figma collab and I really was hoping to control auto layout alignment settings from it. This would make that possible.
  • May 30, 2024
I wondered if the Figma shortcut keyboard included auto layout shortcuts. It seems it doesn’t, right?
Desislava_Slavkova
Please add a shortcut to change direction of autolayout. I do all my designs with that and it would save a lot of time! +1
Jonathan_Puckett1
Please add this feature! 🫰
Alok
  • September 10, 2024
Here are the Auto Layout-related shortcuts for Figma as of 2024:
Auto Layout Shortcuts
  1. Add Auto Layout:
    Shortcut: Shift + A
  2. Toggle Horizontal Auto Layout:
    Shortcut: Cmd + Option + H (Mac) or Ctrl + Alt + H (Windows)
  3. Toggle Vertical Auto Layout:
    Shortcut: Cmd + Option + V (Mac) or Ctrl + Alt + V (Windows)
  4. Resize to Fit Content:
    Shortcut: Shift + R
Albin_Brengesjo
Why not let us create our own short cuts? Changing direction of auto layout would increase productivity alot!
Dawid7
  • March 29, 2025
Bump.
Cindy_Wong1
  • May 19, 2025
Bumping this as well, really really really would like an autolayout shortcut to change the direction. Thanks!!
chmcc
  • July 2, 2025
Adding my vote as well! I would use auto layout direction shortcuts all the time.
Tin_Le1
  • October 14, 2025
Bump! We need autolayout direction for sure!
