Nov 10, 2023 6:24 PM UTC
Attach Image to Table in FigJam
I’d like to insert an image into a cell in a table in FigJam so that it moves with the table as it expands and changes size. Currently, I’m just having to drag pictures around with the table as it expands which is fine for one or two images but I have many!
Emilia_Drake
Oct 11, 2024 12:21 PM UTC
Yes! Need this! Our organization moved from using Miro to FigJam but images in a cell is not suportet in fijams table and thats a downside.
Sophia_Polthier
Oct 29, 2024 12:43 AM UTC
Pleeeease do it @dvaliao ! Would be so helpful
Dustin_Hansen2
Jan 24, 2025 9:21 PM UTC
This is one of the best features of Miro - you can add images, sticky notes, and other objects inside table cells, and the cell and row widths and heights adjust automatically. Without this feature, I don’t find the table widget very useful. (Or FigJam in general, for that matter, since I use tables 90% of the time.)
(Was excited to find you could import boards or frames from Miro - and it does convert the notes - but then realized not only does it not actually convert the table, but even if it did the notes in FigJam wouldn’t actually be inside the table but just sitting on top of it. 😕 Disappointing.)
Dustin_Hansen2
Jan 24, 2025 9:33 PM UTC
 Another post that this one might be merged into:
Amy Taylor
Feb 10, 2025 5:48 AM UTC
+1 for this!!
Jessica Huang
Feb 19, 2025 8:23 PM UTC
This needs to be done asap!! Everyone else is doing it and I want to keep using Figjam. Alas...
Kirk_Wheeler1
Feb 27, 2025 3:54 PM UTC
I’m trying to do this today, only to find out it doesn’t work. Would love to have this feature and stay out of excel
Ingvild1
Mar 14, 2025 1:19 PM UTC
This feature is necessary in tables!
I found a workaround for what I needed to do today. I made a table in Figjam and placed images manually where I wanted them and wrapped the table in a section, then I could export the section to PDF so I could send it to someone.
Arthur Grau
Mar 19, 2025 12:16 AM UTC
Agreed, would be an ideal feature.
Aline9
Apr 2, 2025 7:13 AM UTC
+1!!!
