Viacheslav_Poliakov1
Jun 26, 2023 12:38 PM UTC
Assign variables to variant properties of the main components & nested instances
I haven’t found this in “coming soon” for variables…
As it works now, a variable can control properties only of the topmost component instance. You have to assign a variable again and again to each instance each time you place it, you can not nest components with variables at all.
Martyn_Bowis
Jun 29, 2024 4:48 AM UTC
Hey Friends,
I have created a plugin that can help with packaging components and component sets (variants) with variables, and enabling insert of such as component sets, components and instances with variables still attached to their source (global) or cloned as local variables.
Check it out at Figvar.com or just search for the Figvar plugin.
Cheers,
Martyn
Frank_Chen_TEAMS
Aug 16, 2024 8:37 PM UTC
Please support assigning a variable to an exposed property in a component. In Microsoft, components are heavily used in design deliveries between disciplines. An example would be from UX to CX (Writer). Being able to assign a variable to an exposed property in a component, especially when multiple instances are used, dramatically reduces the amount of laborious work to manually update all the instances.
I see that similar requests have been submitted as early as 2022. I was wondering the reason this is not supported. Thank you!
Ali_Ghane1
Sep 2, 2024 12:11 AM UTC
Wasn’t this obvious from the start?!!! It’s been more than 1 year since variables are released and this MUST HAVE feature isn’t available yet? How can it be? And all we get is new UI, which btw makes it harder to access basic features. :///
UX_Team3
Oct 31, 2024 2:18 PM UTC
Agree there – how can it be that a UX/UI tool has bad UX? 🤦‍♂️ is getting worse with each update, not to mention not able to adjust the UI’s scale? I have a 27 inches monitor and still struggle to read the absurdly small font on the Inspector!
Eva_Willebrands
Nov 7, 2024 4:16 PM UTC
+1 for this feature, I use nested components all the time and don’t want to break the dependency
Alyssa_Maac2
Dec 19, 2024 4:46 PM UTC
Keeping this idea alive +1
Leo_Vogel2
Feb 11, 2025 5:46 PM UTC
+1 for this feature
Mar 27, 2025 10:42 PM UTC
Yes +1.  So many limitations with nested variables :(
Jeroen9
May 14, 2025 11:51 AM UTC
Would really love this. I don't understand why this hasn't been in any of the releases over the past years, as it seems like a very obvious feature that makes variables actually useful. Instead, we get all these beta products that nobody asked for.
Maciej_Mozejko
Mar 25, 2026 7:51 AM UTC
It’s my most wanted feature right now
