Jeremy Kanter at Plume
Jul 14, 2026 5:14 PM UTC
"Apply variable" panel searches text string names but not text string content
When applying a text string variable to a text layer, it’s not possible to search for a text string by content, only by its name. This is rather inconvenient for the localization plugin we’re using, which gives each string variable an inscrutable number for a name.
Here I am searching for “smith” in this panel and getting no results, even though we have variables that contain the text “smith.”
The good news is that if I open the variables panel, the search field there is able to search for string content in the various modes. It would just be great if the little “apply variable” panel could as well!
    Jul 14, 2026 10:01 PM UTC
    Hi ​@Jeremy Kanter at Plume, thanks for flagging this!
    I completely understand how this must be affecting your workflow. You're right that this is a real gap. Right now, it is expected that "Apply variable" only matches against a variable's name, so if your localization plugin is handing out non-descriptive numeric names, that search box won't surface the string you're after.
    As a temporary solution, the full Variables panel search you mentioned does index by content, so pulling that up (via the swatch's "..." menu or the Assets panel) should get you to the right variable, just with an extra click or two versus the inline picker.
    Please know that the team is aware of this gap in the Apply variable panel specifically for text/string variables. Two quick questions that'll help the team:
    • Roughly how many string variables does your localization plugin generate per file (dozens, hundreds, etc.)?
    • Are you seeing this mainly in Design or also in Dev Mode?
    These details will help us gauge how much friction this is causing and get the right context to the team. I’ve updated your topic into a feature request. Thanks again for calling this out!
    Jul 15, 2026 2:03 PM UTC
    Thanks for the response!
    We’re somewhat early in the process of getting localization into our design system in Figma. We have about 200 total string variables now, and my extremely rough estimate based on how much of the app we have currently have covered is that we’ll probably be at around 600 when we’re done. Each variable currently has 17 modes, and we do plan for that number to increase as we continue adding support for new languages.
    We’re seeing this mainly in design mode, as that’s where our localization PM is setting up translations and our product designers will sometimes need to apply them. Dev Mode, as far as I can tell, doesn’t have an apply panel, and the full variables panel search does search the full content. So I don’t really think it’s an issue there. I don’t spend much time in Dev Mode personally, but if I hear any complaints I’ll share them here.
