Mark_McIntyre
Allow percentages for line height
Firstly great job Figma Font variables are here!!!
The only thing missing is the use of percentages in the line-height property.
You can not use a percentage in the line-height as it only accepts variables that are a number type.
Although the variables for line-height caters for pixel (absolute) line-heights (10,12,14)- it does not accommodate relative line heights.
In other words you can’t use percentage variables for line heights that are a percentage of the font size (100%, 120%,150%).
Interestingly …You can use a variable for letter-spacing ( which accepts a number variable - but reads it as a percentage) - the challenge remains that line heights by default are absolute not percentages - even though you can input a percentage.
Percentages allow greater flexibility and less calculations
Word around would be to allow formula in a variable
e.g. =[variable] * 1.5
Or figuring out a way for the line height to be toggle between absolute or relative application of the number variable.
Dominik_Markusic_Gross1
Hi there! Just hit a wall on this same issue and wanted to add my +1 to it!
My expectation from the line-height field in Figma was for it to accept (at least some of the) values as in the CSS spec of the line-height property:
  • 1.25 = If defined with just a number, interpret it as multiplier of font size, which would allow us to declare it in variables as number
  • 125% = If defined with a percentage symbol, interpret as a multiplier of font size
  • 20px = If defined with px, interpret as a pixel constant
Fingers crossed the team sees this issue and prioritizes it!
Michael Fehrenbach
+1, along with the rest!
I’m not hand-waving whatever technical hurdle this might be—but I’ll add that this seems like a real feature, solving a real problem, that real designers (real customers) want to work for their real systems on their real projects. (Unlike some… other things that seem to get the product attention, since this suggestion was raised!)
Patrick_Hill
+1
Mart_Knibbe
Yes please! This feature is basic but really needed.
Matt Molloy
Wait, wait, wait. Have I just poured 2 days of work into converting a design system to use variables, only to find out that I can’t actually finish the task?
Martin_Schilde
Yes, needed.
Purplex Design
I’m suprised that this isn’t a function given how long ago this was raised. Just the ability to scope text strings to the line height value so we can create % text strings would be a start.
Matthew Chaffe
Me too please.
Joe_Garlick
March 19, 2025
This was raised quite a long time ago, this should be implemented ASAP.
Jeyps
up!
