Mark_McIntyre
Apr 17, 2024 10:09 AM UTC
Allow percentages for line height
Firstly great job Figma Font variables are here!!!
The only thing missing is the use of percentages in the line-height property.
You can not use a percentage in the line-height as it only accepts variables that are a number type.
Although the variables for line-height caters for pixel (absolute) line-heights (10,12,14)- it does not accommodate relative line heights.
In other words you can’t use percentage variables for line heights that are a percentage of the font size (100%, 120%,150%).
Interestingly …You can use a variable for letter-spacing ( which accepts a number variable - but reads it as a percentage) - the challenge remains that line heights by default are absolute not percentages - even though you can input a percentage.
Percentages allow greater flexibility and less calculations
Word around would be to allow formula in a variable
e.g. =[variable] * 1.5
Or figuring out a way for the line height to be toggle between absolute or relative application of the number variable.
Matthew_Ryan
Oct 1, 2024 7:38 PM UTC
Another +1 for this. Our existing design system, which we are porting to Figma, exclusively uses percentages for line heights. With 11 line height options and 12 font size options, using variables for line height would require 132 distinct variables to be defined, and would be a major barrier to technical integration between our CSS and Figma component libraries.
Cassie11
Oct 2, 2024 11:53 AM UTC
This is 100% needed, line-height and letter-spacing variables are essentially useless without string input allowing for percentage based values.
Shirley_Wang1
Oct 7, 2024 8:29 AM UTC
1000% needed!! Most of us are working with multiple font sizes switches or responsive resizing, the % would help out a lot rather than working out formula and creating multiple collections/library just to control font sizes.
Michal_Kucera
Oct 12, 2024 10:07 AM UTC
Needing this as well!
Matthew_Ryan
Oct 16, 2024 9:31 PM UTC
I have been thinking about this some more and it seems like the fundamental issue is Figma’s insistence that number variables cannot have units, even though the attributes we can assign those units to may have units. It seems like a way for Figma to resolve this would be to create a new variable type called “units” or something like that, which would allow things like percentage, px, rem, etc.
Alternately, there is clearly some kind of parser that takes strings and converts them into numbers with units, which is what allows us to type in values with units into various fields in the interface. Perhaps instead Figma could allow strings in fields that take units, and the same parser would interpret the string into the value/unit.
Sanny
Oct 18, 2024 11:38 AM UTC
@figma
Any news on this topic?
Our frontend developers are complaining!
Oct 23, 2024 12:02 AM UTC
A MUST! Please Figma 🙏
jessie1
Oct 23, 2024 10:51 AM UTC
I need this too, until then we’ll have to add it in styles but it’s much more cumbersome…
Miguel_DOMO
Oct 30, 2024 1:54 PM UTC
Percentual variables for line-height please! I needed badly for creating cohesive design systems.
Simon_Hagleitner
Oct 31, 2024 2:50 AM UTC
I’m upvoting this. seems like a relatively easy fix for an issue having huge negative impact on design systems.
