alex_personio
Jun 12, 2026 1:51 PM UTC
Allow percentage values for min/max width on auto layout frames
Frames should support a max width defined as a percentage of their parent frame.
I run into the same scenario repeatedly: I have several frames in a composition set to hug their contents, so the parent frame wraps them once they grow past its width. The problem is:
  • When a frame is set to hug, max width only accepts px values, which isn't responsive.
  • If I switch it to fill, the parent container never wraps it, because the frame no longer has an intrinsic width.
So the min and max width/height on auto layout children only accept pixel values, this makes them break down in responsive compositions, since a px cap doesn't adapt when the parent resizes.
The suggestion here is allowing percentages making these constraints behave the way they do in CSS, so you can use values like max-width: 100% or min-width: 50%
Today the only workarounds are hardcoded px values or restructuring layers, both of which fall apart as soon as the composition needs to respond to different widths.
Armin_Rouhanian
Jun 13, 2026 11:47 AM UTC
​@alex_personio Hey there.
This feature have been suggested before, I suggest closing this thread and joining the other one. By upvoting (liking) the other one, there are higher chance for this feature to be implemented. Here is the link:
I also suggest to close this thread and add your own reply in the other thread.
Hope this helps :D​
Armin The Riverman
