Solo_Cube
Apr 29, 2021 1:24 PM UTC
Allow nesting component instances into the same instances (not directly)
Intro
There is an interesting concept in Figma that’s used and was presented by multiple people and has different names: Placeholder, Slots, Dummies, Layout Blocks, and so on:
  1. ❖ Placeholder component is the base one.
  2. ◇ Placeholder instances may be nested into another ❖ Component.
  3. ◇ Placeholder instances nested into ◇ Component instances may be swapped with any other component instances…
    More details in this video by @Adam_Ruthendorf-Przewoski.
    The next step of its evolution is Layout Blocks by @Mr.Biscuit.
An issue
  1. I have a base ❖ Placeholder component:
  2. ◇ Placeholder instances may be nested into other components (❖ Column here):
  3. What I need is to nest a ◇ Column instance into another ◇ Column instance by swapping one of the ◇ Placeholders.
    This is needed to customize Auto Layout spacings and other properties:
  4. But when I try to do this I see an error message Failed to set component: cycle detected!:
I totally understand why we’re not allowed to nest instances into their Main components — it will create an endless cycle such as infinite screen share:
But actually, it is not endless — we always will have the last one ◇ Placeholder instance as a stop point:
My Demo file to better understand what’s going on.
Possible solutions
There are a couple of solutions that solve this issue but still are not optimal:
  1. Have multiple absolutely identical components to nest one into another.
  2. For the upper-level use a component with more placeholders inside and hide unnecessary ones.
Aug 1, 2024 12:52 PM UTC
Are there any better workarounds known meanwhile?
Juan_Guzman
Dec 24, 2025 12:36 PM UTC
Is there any progress on this? Will the  new slots  support this?
