bear
Apr 22, 2021 8:49 PM UTC
Alignment Options in Image Fills
As I was looking for a way to do this natively in Figma, I came across this concept article on Medium. In the article, Андрей Насонов (Andrey Nasonov) describes adding the option to choose alignment in the image settings beyond the default centered. This would be a simple but huge improvement to image settings, especially for responsive design.
Here’s his example of how that might look on the Properties Panel for images:
If anyone has found any way to work around this other than individually cropping images for different container widths, pls hmu! 🙏
Universalnick
Jul 2, 2024 1:03 PM UTC
Just as I thought. Figma is turning into Adobe - prepares fancy features, abandoning basic functions.
Michael_Staton
Jul 2, 2024 2:17 PM UTC
I will raise you one: we should be able to use Images as Component Variants. We are often designing complex marketing sites. The way we manage it now is a time consuming workaround. We have to create shapes, manage the fills and the fill styles, and then make them Component Variants. We should just be able to add our Image Library and allow swaps the same way we do with Components.
S_e_b_a_s_t_i_a_n
Jul 15, 2024 1:23 PM UTC
Wating for this a long time
Robert_Wildling
Jul 16, 2024 7:59 PM UTC
Would love to see this functionality, too!
HJW
Aug 21, 2024 12:08 AM UTC
Just started using Figma coming from Illustrator. It’s absolutely shocking that this isn’t possible in a modern digital design tool in 2024.
Alexey
Sep 22, 2024 3:29 PM UTC
Really need this. I wish instead of useless UI updates Figma would listen to its users and actual problems we need to solve every day.
van_de_Velde_Tim
Sep 25, 2024 9:10 AM UTC
I would argue that we need vertical and horizontal percentage instead of top/center/right etc for more control.
This needs to happen, especially with responsive prototyping happening. Screen sizes change and background-position has been around since the Internet Explorer days.
Julia_Shlyapnikova
Nov 27, 2024 1:09 AM UTC
+1. This feature may seem insignificant, but it would be a huge help. Please don’t dismiss it
SomethingFishy
Feb 14, 2025 5:24 PM UTC
+100
This is pretty vital for supporting responsive design.
Figma is lipstick on a broken box layout where component interactions dissolve on contact with other pages.
pietrogregorini
Mar 5, 2025 7:52 PM UTC
I need this so badly too 🙋🏻‍♂️
