Stephanie_Smith
Nov 12, 2021 3:50 PM UTC
Add the ability to wrap text around objects
There’s currently no way to wrap text around an object like an icon, spot illustration, or image.
The only solution is to manually break the copy into 2 text boxes and add the second one underneath the icon.
We had big plans for our design system to include scaled variants of components where text would need to wrap around icons and spot illustrations to save screen space. So not having this feature makes it hard to design for accessibility and see how components will scale. It’s a little tricky to get the line height right, and also means we can’t easily add scaled variants to our existing design system library. It’s also stopping us from creating a plugin where designers could stress test their designs with larger accessible fonts.
Would be great if Figma could add this as a feature.
Has anyone else had this issue? Is anyone using a plugin or workaround to help solve this?
    Polyprism
    Mar 17, 2025 4:48 PM UTC
    Adding another upvote for this - nuts that it isn’t in Figma considering this is *so* easy to do in HTML!
    Janice_Tsai
    Apr 30, 2025 8:26 PM UTC
    +1 for this! Not being able to have an icon trail text makes our link component a poor representation of behavior. Same with multi-line input labels that are trailed by a “help info” icon.
    Bauke_Schildt
    May 8, 2025 10:17 AM UTC
    My hacky solution for this is to have a “Tooltip positioner” element that’s Absolutely Positioned to the bottom right and then position the tooltip by adding right-padding.
    Recreation of the text component from our library showing how to manually position a tooltip icon at the end of your text.
    It doesn’t work with auto-layout, and it’s a lot of manual work every time you change, well, anything, but at least it prevents my fellow designers from using groups and from having to manually get the tooltip component from our Library.
    Bauke_Schildt
    May 8, 2025 10:18 AM UTC
    PS: +1 for fixing this, Figma…
    Paul_Nattress
    Jul 18, 2025 12:57 PM UTC
    Another +1 for fixing this please. I have several hacky workarounds that never work properly for this.
    ScottF
    Aug 12, 2025 9:27 PM UTC
    Adding my +1 to the mix!
    Tien Vi
    Aug 26, 2025 7:14 AM UTC
    +1! Can’t believe this topic has been there for 3 years and it’s still not there.
    Olivia_Gulin
    Sep 15, 2025 8:31 PM UTC
    This would save my life, please add this
    Nathan Low
    Sep 15, 2025 8:56 PM UTC
    test
    Sep 26, 2025 5:26 PM UTC
    This seems like a no-brainer. Would love to see it. Any idea if it’s on the roadmap?
