Mike_Higham2
Apr 16, 2024 9:34 PM UTC
Add margins to objects without having to frame them
When using Auto Layout for an entire page flow, not everything is spaced equally. For example, imagine a page like:
  • Toolbar
  • Heading
  • Paragraph
  • Input
  • Button
To put all of these into a single Auto Layout and give equal spacing to all of it is not typically how it’d work (eg, Toolbar + Heading might be close together, but more spacing around above and below the Input).
To use the benefits of Auto Layout, I wrap these objects into their own Auto Layout frames and then use the padding within these nested frames to create the spacing between elements.
It’d be great to be able to apply margins to objects (like text frames or other frames) without having to first nest them into their own individual frames. This would be closer to how CSS typically works as text elements (h1, h2, p, …) don’t need to be nested in a div to have margin added to them.
Mike_Higham2
Apr 16, 2024 9:35 PM UTC
(When I say, “not everything is spaced equally”, I don’t mean there is a bug in Figma. I mean that “I might not want everything to be spaced equally” 🙈
Apr 18, 2024 5:44 AM UTC
Hi there,
Thank you for sharing your idea! We greatly value your feedback, and we would like to gauge the reaction of other members in the community. We may consider it for future enhancements!
Toku
Jobin
Aug 22, 2024 2:10 PM UTC
Hi Toku,
I agree with Mike_Higham2, that would be a nice feature to have 🙂
Best,
Jobin
Tom_Auger1
Aug 22, 2024 4:42 PM UTC
You should then add your vote! So far, there hasn’t been a lot of votes on this issue (which may be a duplicate of others), so add your voice.
Joaquin2
Sep 6, 2024 3:05 PM UTC
This would be a great feature, and honestly seems pretty reasonable. Isn’t the goal ultimately for web and UI designers to be working in an environment that mimics or even replaces front-end development? All for the sake of better handoff. Vote up!
Przemek3
Nov 6, 2024 9:32 AM UTC
Hey, maybe not a disruptive change, but would it be possible to add padding options for text boxes? For now, to have it padded, you need to wrap it with a frame.
HowardHughes
Feb 8, 2025 12:42 AM UTC
I’d like to second this motion. It’s just silly that I have to add a frame around an item in order to add margins or padding to it. It doesn’t reflect how CSS works, and it makes the file structure unnecessarily complicated.
Sibylle1
Sep 26, 2025 3:54 AM UTC
It would simply be nice if Figma behaved like CSS. In CSS, we have margins and paddings and there is a reason for that. The way it currently works causes developers to add unnecessary code, because they will simply adopt the same structure for an element as in Figma. How are they supposed to know when to wrap a paragraph in a div and when not to?
Also: In real life (CSS and HTML) margins collapse. In Figma, they don’t. So I need to create components with and without “Figma padding”. Unnecessary work.
loodough
Feb 11, 2026 3:53 PM UTC
I don’t understand how we can connect Figma and code together if we can’t have such basic CSS properties. Without margins in my designs, I can’t recreate the way code was formatted by the developers I work with.
Tobias_Frithiofsson
Mar 16, 2026 3:20 PM UTC
Agree - what we really need is a feature for margin! Padding works today, you have to frame it, like in html. But there are no work around to get the same function as margin in figma ☹️
