Midori.H
Jul 10, 2026 2:09 AM UTC
Add Google's Antigravity IDE to the Figma MCP Catalog
Hi Figma Team,
The Figma Remote MCP is amazing, but we currently cannot use it with Google's Antigravity IDE. When attempting to connect to `https://mcp.figma.com/mcp` via Antigravity, the connection is rejected (Unauthorized) because Antigravity is not yet a supported client in the Figma MCP Catalog.
Antigravity is an incredible GUI-based AI coding assistant, and I use it extensively for mentoring students. It is much more approachable for beginners than CLI-based agents (like Claude Code or Gemini CLI).
Please collaborate with the Google DeepMind team to whitelist and officially support Antigravity in the MCP Catalog. It would be a massive game-changer for design-to-code workflows in education! Thank you!
    Morgan Keys
    Jul 21, 2026 4:04 PM UTC
    +1 to this!
    I’m able to set up the MCP, but the key feature I need is the use_figma tool to be able to close the loop between designs and code and back again.
    Ryan Despain
    Jul 22, 2026 7:19 PM UTC
    Yes, please. Any movement on this?
    https://antigravity.google/docs/mcp#supported-mcp-servers indicates Figma is already supported so I’m quite confused.
    Jul 22, 2026 9:34 PM UTC
    Hey All, thanks for reaching out about this!
    I understand how this must be affecting your workflows. Here's the nuance that explains what everyone's running into: Antigravity is currently supported via our local/desktop MCP server only, with read-only access to Figma Design and FigJam. A couple of things that likely explain the trouble:
    • ​@Midori.H: The `https://mcp.figma.com/mcp` URL you tried is our remote server endpoint, which isn't part of Antigravity's current support. Could you try connecting through the desktop/local server setup instead and let us know if that resolves the "Unauthorized" error?
    • ​@Morgan Keys: Since Antigravity's access is read-only right now, `use_figma` write-back (closing the code → design loop) isn't available for it yet, independent of local vs. remote. That's a current product limitation rather than a configuration issue on your end.
    I've also ensured this topic is in our Suggest a Feature category, so Midori's original ask “full (remote + read/write) Antigravity support” stays visible and tracked as a feature request for our MCP team. In the meantime, if the round-trip write capability is the main blocker for your workflow, some of our fully read+write clients (Cursor, Claude Code, VS Code, Windsurf) might be worth pairing with Antigravity for the write side.
    Morgan Keys
    Jul 23, 2026 3:35 PM UTC
    Thanks djv!
    Yeah, my understanding is specific clients have to be enabled/whitelisted for write access. It looks like the Gemini command-line (CLI) is enabled for write access but Antigravity is not?
    I’d love to be to use Antigravity to write to Figma—it would really help my workflow!
