Mushon
Jun 22, 2023 9:32 AM UTC
Add Auto Layout Wrap from right to left
A ton of great features launched yesterday. One of them is Autolayout Wrap. It might be just me but I couldn’t find how to wrap from right to left. This seems weird as Figma did an amazing job of closing its long technological debt when it comes to RTL languages. Please tell me this gap has not been reopened again…
Walker_Glenn
Jul 26, 2024 11:00 AM UTC
Good work! This is the best solution i have found to achieve this.
Abdessamed_98
Dec 23, 2024 3:13 AM UTC
Yes . Figma we need RTL
Lidor_Batino2
Jul 6, 2025 7:45 AM UTC
So Agree
Negin
Aug 6, 2025 8:37 AM UTC
Hello Figma team,
First of all, thank you for your great work on Figma — it has truly transformed the design workflow for many of us.
I’d like to request RTL (Right-to-Left) support for the Wrap feature in Auto Layout.
Currently, when using Auto Layout with horizontal direction and Wrap enabled, the elements are wrapped from left to right, which works perfectly for LTR languages.
However, when designing interfaces in RTL languages like Arabic, Persian, this behavior causes layout issues. In RTL layouts, the natural expectation is for the second line to wrap from the right, not from the left — but this is currently not possible.
Although reversing the order of elements helps with initial alignment, it does not fix the direction of wrapping, which leads to awkward designs and manual workarounds.
Adding RTL-aware wrapping logic in Auto Layout would be a huge improvement for designers working in RTL environments and help Figma better support global design needs.
Thank you for considering this request.
Mar 17, 2026 6:10 PM UTC
This seems a no brainer. I have many instances where I need this feature, and instead of using auto layout, I am forced to build a second version of the layout to display it with the proper wrap order at those breakpoints.
Yoni_Kessler
Apr 16, 2026 10:35 AM UTC
Fully supporting this request! As a designer working extensively with Hebrew interfaces, this is one of the most frustrating gaps in Figma's RTL support.
The Wrap behavior in Auto Layout is great — but when you're designing RTL layouts, it completely breaks the natural flow. Elements that should wrap from the right end up starting from the left on the next line, which forces us into manual workarounds that are time-consuming and hard to maintain.
This is especially painful when working with tag systems, chip groups, or any component that uses wrapping. The current workaround of reversing element order only partially solves the alignment issue, but it doesn't fix the wrapping direction itself.
RTL support is not a niche request — it affects hundreds of millions of users designing for Arabic, Hebrew, Persian, and other RTL languages. Figma has made great strides with RTL text support, and adding RTL-aware wrapping logic to Auto Layout would be a natural and impactful next step.
Please prioritize this — it would make a huge difference for the RTL design community!
111695
Apr 16, 2026 10:39 AM UTC
Please, this is really important and difficult to work like this in Hebrew software.
Sara_Katz
Jun 8, 2026 4:15 PM UTC
Wow this is so important and missing
