Matty_Vazquez
May 12, 2023 9:45 PM UTC
Add a Highlighter for Text to the Type Settings
Allow us to change the background color of text (not just the text fill color) to give a highlighter effect that stays with the words that the effect is applied to even when the size/shape of the text box is changed.
For example:
The above shows two examples of the same ipsum (left and right) where specific words are highlighted. When the size of the text box (the left example) is changed to accommodate a responsive layout (the right example), the highlighting stays with the selected words.
The way to add highlighting for the above examples could be included in the type settings pop-over:
Note: the idea here is that the user can apply this to specific sets of selected characters within a text box or to the entire text box, just like how all of the other type settings already behave.
Daniela_Zerlauth1
Sep 17, 2024 4:07 PM UTC
Yes please. I really need this for my clients. I do crazy workarounds.
Stephen_Deutsch
Sep 27, 2024 2:55 PM UTC
+1 to this feature. We can really use it!!!
Oct 22, 2024 5:44 AM UTC
Please we need this :,)
Michael_McCann
Oct 24, 2024 8:39 PM UTC
+1 for this feature, please!
Alec7
Oct 28, 2024 9:46 AM UTC
+1 for this feature, me too.
Alan11
Oct 31, 2024 10:55 AM UTC
Yes please, even as basic a feature as it seems, it would be an incredible update +1
Piper.Canonical
Nov 4, 2024 8:43 PM UTC
+1, I need this feature as well
tank666
Nov 8, 2024 1:34 AM UTC
And again, hello to everyone! It looks like Figma is a little closer to achieving the goal and is almost releasing the feature we need. Now, pay attention: you can create a text highlighter with just 3 layers. I’ve published an update to my file in Figma Community, adding a highlighter v2 component that uses the new method. You can check out and duplicate the file here: Hacked Auto Layout with Multiline Text Highlighted | File by Yury Zeliankouski.
Krystian_Kubicki_Shiji
Nov 25, 2024 10:37 PM UTC
I found a simple workaround using underline. No components or anything else is needed. You can use one text layer or even create a reusable text style.
Select Text:
  • Go to underline details
  • Change settings to:
    Decoration: Underline
    Thickness: 120%
    Offset: -100%
    Color: 30%
    Skip ink: Off
More techniques, like highlighting with full color instead of transparency, are visible in the file :):
Easy Way to Highlight text in figma
Matty_Vazquez
Dec 2, 2024 4:19 PM UTC
This is a nice little hack and has the nice side effect of highlighting any text that you underline in a paragraph of text if you apply the underline detail changes to the entire block of text. The only downside is that it can’t do solid colors since the text gets rendered behind the underline. I have also noticed a slight color change of the text that gets highlights because of the same reason. Cool idea though!!
