Marx_Oliva
Apr 7, 2026 4:23 PM UTC
Actually responsive tables on figma
Can’t do truly responsive tables in figma.
I design complex applications that require a lot of tables. Currrently, there are two primary approaches to responsive tables in figma: row-based and column-based.
In reality, neither of these is fully responsive. In row-based ones, when a cell's content expands in height, all cells in that row adjust accordingly. However, if the content expands in width, the cells that are supposed to be in the same column don't follow suit because there is no relationship between them. The same happens with column-based tables, but the issue lies with the height.
There is another approach called grid-based tables that almost solves that issue. The downside is that you can't use components in a simple way, like slots. If you need to create a prototype with hover effects, the interactions will trigger a single cell at a time, rather than the entire column or row. If you try to group cells into rows or columns within the grid, you fall back into the issues mentioned above.
I’m not sure how to solve this with Figma’s current features (I don't think it's actually possible right now), but I wonder if future updates will finally address this.
Dustin_Hansen2
Apr 9, 2026 1:34 PM UTC
Strongly agree.
There is a fantastic plugin called Table Creator that solves 90% of this, try that out if you haven’t already.
https://www.figma.com/community/plugin/885838970710285271/table-creator
Marx_Oliva
Apr 10, 2026 12:45 AM UTC
Strongly agree.
Pretty amazing solution with components I would say. Thanks for that recommendation! This will save me hundreds of hours of work doing tables! It doesn’t solve all the problems, but it’s fine for me.
Hope we can do it without plugins in future updates.
Jason Brown
May 1, 2026 8:43 PM UTC
It’s amazing that in 2026 we still don’t have a tool in Figma to build a data table that is responsive and supports full row and column prototype interactions, content wrapping, etc. Everything is a half baked workaround. It’s almost there with the slots feature, but it’s so limited and buggy you can’t rely on it. I’ve wasted so much time researching and trying. Figma, it is time to build a native table component….waaaay past time actually.
