Hannu
Feb 1, 2021 9:23 AM UTC
A way to export/import styles (text + colors)
I’m working in an agency developing (among other things) design systems for our clients. Recently we ran into an issue while transferring a design system project we had started, to the client’s organization. Without going to too much detail (we are solving the issue with Figma support) a lot of headache could have been avoided, if styles would be as easy to transfer between files, as components.
At least to my understanding, there currently isn’t a way to transfer/copy&paste a style from a Figma file to another (w/o plugins at least).
Am I the only one missing a native feature in Figma to achieve this? Also, handling multiple style values and descriptions at once would be fantastic! This is possible with plugins atm. But I think it would be welcome feature to have better style management natively in Figma.
Siryi
May 30, 2023 6:59 PM UTC
Dudes why use plugins or other headache if you can cut the style to other file and then just paste where-ever needed? (hope figma doesn’t remove this hack lol)
Dennis_Kuiper
Jun 1, 2023 6:30 PM UTC
Wish we could just load in JSON files easily. Would be nice if we can connect it to Gitlab/hub so devs and designers use the same source for styling.
Arun_Pich_Ream
Jul 21, 2023 8:06 AM UTC
For your information, I had found a plugin where you can import and export style from one file to another which is also a free plugin.
Style Transfer
Figma
Caju
Apr 30, 2024 8:22 AM UTC
Hello, I’ve found a way.
Select (Shift + Click) the text/colors styles from the file you want > Right click > Cut Styles > Then press Cmd Z to re paste the styles on the original file.
Go to the new file and right click on styles and choose paste.
Janine_Shroff1
Jun 14, 2024 4:19 PM UTC
omg thank you! glad they added this update to styles. hopefully it’s also in variables!
Simone_Salvucci
Oct 24, 2024 9:41 AM UTC
The solution is this plugin to copy/paste style between files.
Works with any type of styles. Colors, typography, effects and even grids styles!
https://www.figma.com/community/plugin/1424844302061301564/copy-styles
Give it a try!
