Rishabh Gupta
Apr 30, 2026 7:38 PM UTC
Our Figma sidebar had 8 plugins open. Now it has one.
You know the flow: export a PDF in one, check contrast in another, convert units in a third, then open yet another tool just to import a file. Each has its own UI, pricing, and quirks. Half the time the work is simple — but finding the right plugin becomes the work.
So we built Waysorted.com.
It's a lightweight Figma plugin suite that pulls common design utilities into one place. Beta 1.0 is live now:
  • PaletteTable — color systems with harmony schemes and WCAG/APCA contrast checks
  • Frames to PDF — DPI control, RGB/CMYK, reordering, merging, compression
  • Unit Converter — MM, CM, IN, rem, em → pixel values, with direct frame creation on canvas
  • File Importer — drag and drop AI, PSD, EPS , PDF, Canva files straight into Figma
  • SVG Icon Library — browse, export as components, or copy URLs for dev handoff, with 20+ Icon packs
  • HTML to Design — converts coded interfaces into editable Figma layers
Free to start!
Honestly curious: which small Figma plugin do you wish was just built into something bigger?
We’re also building in public through Request a Feature, where users can suggest the tools and workflow improvements they want next — so Waysorted grows around real designer pain, not guesswork!
🔗 https://www.figma.com/community/plugin/1532842109377504268/waysorted-plugin-suite-pdf-export-color-accessibility-unit-converter-import-ai-psd-eps-icons
