Benjamiz
Jan 8, 2026 11:50 AM UTC
Build tables using your own styled cells, generate/write/paste csv, and easily switch row/column layout
I made a table plugin to generate tables easily in my styled cell components using realistic mock data, and easily adjust the layout.
Making a table is long. Group by column so you can adjust column width, but then how do you hide a row? Do it by row and now how do you adjust column width or change column order? Even after sorting that out, you have to go put realistic data into the cells, cell by cell. Long.
I found I was mocking up at least one table a month, so I decided to build a plugin to make it easier. GenTable is iteration 3.
Features:
  • Generate realistic mock data from prompts. "15 users, half active, half pending" creates the whole table.
  • Map your cell components once. Tell it your Status column uses your Status Chip component and it picks the right variants automatically based on the data.
  • Switch between row and column layouts anytime. Need to adjust column widths? Switch to column layout. Need to hide rows? Switch to row layout. Same data, different structure.
  • CSV import that actually works. Handles commas and quotes properly.
  • Comes with basic table components you can customise or replace with your own.
Try it:
https://www.figma.com/community/plugin/1590248825727689288/gentable
It's free, just need to get your own API key from https://aistudio.google.com/api-keys. Leave comments so I can make improvements.
