rrrrrrami
Sep 3, 2025 8:04 AM UTC
Open overlay bug when frame is in a slide
When you create a prototype with the Open overlay interaction to trigger a bottom sheet, it works well, until you actually want to put that prototype in a slide. Once you include it in a slide, the Overlay uses the slide as its parent, not the phone screen, so it appears from the bottom of the slide, making the interaction very unrealistic. Using ‘manual’ position doesn’t solve it, because you still see the modal appearing from the bottom of the slide.
To solve this I’ve created an interactive component that fakes the appearance of the sheet by using Smart Animate, but it’s so much work for such a simple use case.
Would be great to get a solution for this, as I assume many people are embedding prototypes in presentations.
Note: when I say slide, I’m not talking about Figma Slides, but the classic slides we’ve been using before that.
Thanks
