juneui
Mar 26, 2026 1:10 AM UTC
[MCP] loadFontAsync fails for locally installed fonts
 I ran into a font issue while working with MCP use_figma and wanted to share it here.
I have a font installed on my system (Pretendard) that works perfectly fine in the Figma UI — it shows up as "Installed by you" in the font picker. However, it's completely invisible to the Plugin API when running through MCP use_figma.
listAvailableFontsAsync() returns around 7,600 fonts, but none of them are locally installed ones. It seems to only return Google Fonts.
loadFontAsync() also fails, and trying to appendChild a component instance that contains text using the font throws a font load error — even into a non-auto-layout frame.
Steps to Reproduce
 1. Install a local font on your system (I tried both ~/Library/Fonts/ and /Library/Fonts/ on macOS)
 2. Confirm the font shows up normally in the Figma UI
 3. Run the following via MCP use_figma:
 const fonts = await figma.listAvailableFontsAsync();
 const result = fonts.filter(f => f.fontName.family === "Pretendard");
 return result.length; // 0
 await figma.loadFontAsync({ family: "Pretendard", style: "Bold" });
 // Error: The font "Pretendard Bold" could not be loaded.
This makes it impossible to work with design system libraries that use local fonts — which is very common in CJK environments (Korean, Japanese, etc.). You can create component instances on the page, but you can't put them inside frames or apply text styles, so you effectively can't build any screens through MCP.
Is there a known workaround for this, or is local font access not yet supported in the MCP beta?
Thanks.
Ronan M
Apr 9, 2026 11:29 AM UTC
I also have this issue, which severely limits the usefulness of the MCP.
Claude seems to think it’s a limitation of how the Figma MCP server runs plugin code — that it “operates in a sandboxed environment that doesn't have the same local font access as Figma's main UI.”
Would love a fix for this!
Ronan M
Apr 9, 2026 11:33 AM UTC
For anyone else with this issue, looks like the question has been addressed in this thread. There’s no fix as yet
adamsmasher
Apr 9, 2026 6:23 PM UTC
Hi ​@Ronan M and ​@TenTen! I moved your replies over to this thread so we can keep the whole conversation in one place, that way you’ll get notified of any updates to this thread automatically.
MattBraun
Apr 14, 2026 6:34 PM UTC
I’m having the same problem!! This is definitely something people are NOT saying on LinkedIn when they talk about how amazing Claude + Figma is.
Anyone find a work around other than manually correcting everything in Figma?
Ali Aas
Apr 16, 2026 12:55 AM UTC
I was able to use the Figma Console plugin and Figma Bridge Developer plugin to do this. You need both running while you use CoWork.
megaroeny
Apr 20, 2026 8:11 PM UTC
​@Junko3 here’s a little more info when I tried another angle with Claude today. (We) concluded this outcome with a failure still
We ran several tests trying to change an FA7 Pro icon via the Figma MCP's use_figma tool and hit the same wall every time.
What works fine:
Existing FA7 Pro text nodes render correctly in Figma because the FA Desktop App exposes the font to Figma's rendering engine.
What doesn't work:
Any attempt to write to an FA7 Pro text node fails — silently, no error thrown — because the Plugin API can't load the font. figma.listAvailableFontsAsync() only returns FA 5 & 6 Free. FA7 Pro is absent, meaning loadFontAsync() will error, and any operation that internally requires a font write (including setProperties on TEXT-type component properties) is silently dropped.
Approaches tested, all blocked:
  1. Edit the TEXT node characters directly → requires loadFontAsync("Font Awesome 7 Pro") → not in the loadable font list → explicit error
  2. setProperties on the nested v7-icon (pro) instance → silently does nothing — changing a TEXT-type prop still triggers an internal font write
  3. Detach all parent instances, then edit the text node → same result, font still can't be loaded
  4. Access via exposedInstances (the correct API for nested exposed props) → v7-icon (pro) is found and accessible, setProperties is called without error, but the icon doesn't change — same silent failure
Root cause:
The Plugin API runtime has a sandboxed font model. Licensed fonts distributed via the FA Desktop App are available to Figma's own rendering engine but are not surfaced to the Plugin API layer. This is a gap between what the Figma UI can do and what plugins/MCP can do.
What would fix it:
Figma exposing locally installed licensed fonts to the Plugin API runtime, or providing a dedicated API for icon component property swaps that bypasses the font-loading requirement.
adamsmasher
Apr 23, 2026 8:51 PM UTC
Hey ​@megaroeny!
Thank you for detailing what you discovered trying to use your Font Awesome font with the MCP; while expected when it comes to using a local font with the MCP, noting what you tested will be helpful for others who are not aware and try any of the tests you documented. Are the other fonts you listed local-only fonts, or were those uploaded to your organization?
Uploading fonts to your organization as mentioned by ​@Junko3  is another solution you can use in the meantime.
designdc
Apr 24, 2026 6:37 AM UTC
Can confirm, uploading fonts to my org has provided a workaround and allowed the MCP to use the local fonts I needed.
megaroeny
Apr 24, 2026 1:48 PM UTC
Hey ​@megaroeny!
​@adamsmasher We're on the Professional plan, so we can't upload to our org. 🙁
adamsmasher
Apr 24, 2026 5:09 PM UTC
Thanks for confirming that, ​@Dan Cheng! Glad to hear that works for you as a solution.
I’m sorry to hear that, ​@megaroeny. I can see how much more of a blocker this for you. I don’t have any specifics on this particular issue, but we are actively working on the MCP - hopefully this is something we can support in a future update!
