Brian_Olson
Sep 24, 2026 6:45 PM UTC
Figma stopped remembering export build
If I
> select a few frames
> create a new export
> then deselect the frames
> then reselect the frames
> the export build is wiped out and I need to start over:
Please restore previous behavior that remembers export build
adamsmasher
Sep 24, 2026 7:51 PM UTC
Hey again, ​@Brian_Olson. I can imagine this is pretty disruptive if you export a lot.
I recall you mentioned in your other post that you use the desktop app. If you temporarily switch to a browser, does it remember your export settings? And just to be clear, it’s only forgetting your export choices when you select multiple frames, right? Does it work correctly with a single frame or layer? Thanks!
Brian_Olson
Sep 24, 2026 8:01 PM UTC
The issue is present in browser Figma too. But it’s sporadic. Seems like half the time there is no export settings remembered half the time there is. I literally selected and deselected the same few frames back and forth several times in a row while watching the export pane, and some of the times the export pane had my export settings, some of the times the was blanked back to default state. Different behavior in back to back attempts at the same action. The same sporadic behavior is present whether I select one frame or multiple.
Brian_Olson
Sep 24, 2026 8:06 PM UTC
It’s also sporadic on desktop now. Different than earlier. Now it’s only wiping build like 1/10th of the time.
