Brie Bae
Nov 3, 2026 6:31 AM UTC
Figma Motion: Developers can’t inspect animation values per layer, which makes design-to-dev handoff difficult
Figma Motion makes it easy for designers to build interactions and animations. But when we hand them off, developers can’t click a layer and see its exact motion values. Because of this, Motion is hard to use as a real collaboration tool with engineering.
Expected behavior
Tools like ProtoPie already handle this well: a developer clicks any layer and immediately sees which properties change, from what value to what value, with what timing and easing. We’d love the same in Figma, ideally in Dev Mode
Why this matters
For most teams, motion design only pays off once it ships in the product. Right now, the gap between building motion in Figma and implementing it means teams either keep using separate prototyping tools for handoff or accept motion that doesn’t match the design. Closing this gap would let Figma Motion work as a single source of truth for both designers and developers.
Thanks for considering this!
Celyn_L
Celyn_LSolution
Nov 3, 2026 6:59 AM UTC
Hey ​@Brie Bae, Celyn here from the Figma Community team.
Thanks for taking the time to share this thoughtful feedback! It really helps us understand how this affects your handoff workflow.
Motion information is available at the layer level in Dev Mode, so we’d love to take a closer look. Could you please share:
  • A link to an affected file, and invite support-share@figma.com with “Can View” access. This won’t impact your billing and will allow us to review the file.
  • A screen recording or screenshots showing what you see when inspecting a layer in Dev Mode.
This will help us better understand what you’re seeing and guide you from there.
Thanks for your help!
Celyn_L
Celyn_LSolution
Brie Bae
Brie BaeAuthor
Nov 9, 2026 3:25 AM UTC
Hi Celyn, thanks for getting back to me!
I don’t think I explained the issue clearly enough, so here’s a bit more detail.
I know Dev Mode shows the layers. The problem is that when a developer selects a specific layer, they can’t see the specs for that layer alone. Right now, the Inspect panel on the right shows the code for the whole frame instead.
Because of this, developers have to dig through the full code to find the values they need for one element. It would help a lot if selecting a layer showed only that layer’s specs, like its size, spacing, typography and colors.
Please let me know if anything is unclear. I’m happy to share screenshots or a sample file.
Figma Link
Jaycee Lewis
Nov 9, 2026 10:44 PM UTC
Hey hey ​@Brie Bae 🤩 Thanks for clarifying and sharing the video and file!
I've shared your feedback internally as a feature request for more granular, layer-specific inspection in Dev Mode to help improve the design-to-development handoff experience.
Thank YOU taking the time to share this feedback! — Jaycee
