Sandy Fox
Nov 23, 2026 3:31 PM UTC
Assets > Insert Instance not 'locking' into selected frame as expected
I’m new to Figma & something is driving me crazy.  When I select a frame, go to assets, select the asset, choose to ‘insert instance’ these instances are not neatly inserting into those frames.  I didn’t know this, and after inserting like 30 things, I went to move some frames around and the instances didn’t move with them.
It seems very obvious that if I have a frame selected and then ‘insert instance’ that I clearly want the instance to be inserted in the selected frame.
Once I discovered this was not working as expected, I spent almost an hour dragging these instances out of the frames and then back into them to fix the issue.
So frustrating.  Figma, maybe you could fix this issue.
