SJ Kim
Apr 2, 2026 8:02 AM UTC
환불
자동 결제일 이전 3월 달에
프로페셔널 구독 해제 및 결제 수단 제거를 했는데,
오늘 17.03USD가 이전 연결했던 결제 수단으로 결제가 됐네요.
팀은 잠겨있고, 저는 더 이상 사용하지 않을 예정입니다.
환불해주시고, 결제 수단 제거가 제대로 되지 않았다면 제거해주세요.
    Celine_Solution
    Apr 2, 2026 9:33 AM UTC
    Hi ​@SJ Kim, thanks for reaching out, and sorry to hear about this situation. Please let me continue in English as I don’t speak Korean, hope it’s ok!
    We are not able to handle billing and refund requests from the Forum due to security and privacy reasons. I can also see that you’ve already contacted our support team — I’ve added a follow-up note on your ticket to give more visibility so they can take a closer look. For reference, your case number is 1827326.
    I’d recommend continuing the conversation directly through your case, as they’ll be best equipped to review your account and assist you further. Thanks for your patience!
    Update: Good news - the support team has solved your issue, please check your inbox when you can!
    If you have any additional questions on this, feel free to reply directly to your case, it will re-open automatically.
    Celine_Solution
