이상언
에러
모든 모델들이 위와같이 에러가 나오는데, 해결 할 방법이 있나요?
Tom Reem
Hi ​@이상언 — welcome to Figma Forum, and thanks for flagging this.
We don't currently offer support in Korean on the forum, so I hope it's okay that I'm replying in English.
Based on what you reported and the error message in your screenshot, it looks like Figma Make is running into a connection issue across all models. Here are a few things worth trying:
  1. Check your connection: Make sure you're connected to the internet, then try your prompt again.
  2. Try a different network: If possible, switch to another Wi-Fi or mobile connection and see if that makes a difference.
  3. Review known error messages: This resource covers common Figma Make errors and how to resolve them: Troubleshoot in Figma Make → Error messages.
If none of that helps, let me know and I'll escalate this for further review. Appreciate you taking the time to bring this up.
이상언
이상언Author
다른 프로젝트에서는 프롬프트가 정상 작동합니다.
현재 이 프로젝트에서만 오류가 나타나고 있습니다.
Tom Reem
Hi ​@이상언 — thanks for the update.
It's really helpful to know this is only happening in one specific file, that narrows things down.
I'm not able to access account-specific details from the forum, but I've opened a ticket on your behalf with our Technical Quality team so they can take a closer look. Your case number is: 1808018. Please check your inbox for an email from me with next steps on sharing file access securely.
I'll keep an eye out for your reply, and appreciate your patience as we work on a resolution.
Tom Reem
Hi ​@이상언 — checking in on this. I've been in touch with our Technical Quality team and wanted to see if you were able to move forward with this project.
Hopefully things are working as expected now. If the issue is still coming up, please check your inbox for the latest reply on your case: 1808018. The team can take a closer look from there.
Thanks again for reporting this. 🙏🏻
