Fangzaijin
May 20, 2026 11:27 AM UTC
我的账号无法使用AI功能
Education plan has AI enabled and other members can use AI, but my admin account cannot see “Rename layers with AI” in Figma Design command menu. My account has edit access to all projects and files.
    May 21, 2026 5:09 PM UTC
    Hi ​@Fangzaijin, thanks for reaching out!
    This definitely sounds odd. Were you able to see the Rename layers AI tool previously? Is this occurring in all file for you or just one file in particular?
    If it is one file in particular, are you able to share a URL link? With the direct link, I can take a closer look at the file’s project/team to determine what may be causing this issue. If it is happening in all files, we’ll be able to better identify our next troubleshooting steps.
    Fangzaijin
    Jun 1, 2026 6:28 AM UTC
    https://www.figma.com/design/JBxI6u3kEzE2cm6YIVutwu/Untitled?node-id=0-1&t=a50CWOgecuIiisHB-1  我确定这个问题出现在所有文件中,这是我备份出来的其中一个文件,请查收,谢谢
    Jun 1, 2026 9:43 PM UTC
    Hi ​@Fangzaijin, thanks for providing a file link and confirming this is happening across all your files!
    From what I can see, you are an Admin with a full seat for this file’s team, so this appears to be isolated to your account specifically. Before we escalate, it may be worth checking a few quick things:
    1. Sign out and back into Figma completely, then recheck the command menu.
    2. Try a different browser or the Figma desktop app to rule out any client-side caching issue.
    3. Check if a newer version of Figma is available:
    • macOS: Click Figma in the top menu bar, then select Check for Updates…
    • Windows: Click the downward caret icon ⌄ next to the window controls (minimize/maximize) in the top-left or top-right corner, and select Check for Updates... from the drop-down menu. You can also access this via Help > Check for updates
    If AI tools are still not appearing after these steps, please let me know, and I can help get you connected with our support team.
