anna_cognyx
Sep 10, 2026 2:13 PM UTC
Why my color variants start acting crazy
Hi!
I was casully changing the variant property of my badges in a list, and they started to act weir. They decided to be pink and reseting the instance or changing the color manually works randomly. I’m now stuck with badges with the correct bg color but not text color. Help?
Thanks !
Sep 10, 2026 9:01 PM UTC
Hi ​@anna_cognyx, thanks for flagging this!
I understand the frustration. The pattern you're describing usually points to a leftover override on the nested text layer that isn't updating when the badge's variant changes. Two things worth trying:
  1. Right-click the badge instance → Reset all changes, then re-apply the variant property. Order matters here; resetting first, then setting the variant, tends to stick better than the reverse.
  2. If the text color still won't budge, select just the nested text layer inside the badge and reset that layer on its own before touching the parent.
A few questions so we can investigate this further:
  • Is the badge's color coming from a variable/mode, or set directly on the layers?
  • Is the badge component nested inside another component or a slot?
  • Did the pink appear right after a library update or a mode switch?
Let us know, and we’ll continue troubleshooting this together.
