Cristian_Banu
Jun 10, 2025 10:03 AM UTC
Why is Figma (desktop version) so laggy?
Hi guys,
Figma didn’t really used to be like this, but now it feels very laggy and has a huge delay between the user’s action and the result. Even a simple drag has a huge delay, I attached a video, check the time distance between the mouse dragging and when the dragging actually occurs. It’s ridiculous. Is there a way to solve this?
EDIT: the lag is not actually in the movement itself, it’s in SELECTING THE ELEMENT. If the element is selected, it moves nice and smooth while dragging, but after clicking an element it literally takes almost a second for it to get selected. I’m not sure how to show that in a video, but it’s insane how annoying this is becoming.
Thank you :)
Gayani_S
Jun 10, 2025 12:09 PM UTC
Hey ​@Cristian_Banu, thanks for flagging this!
It looks like the screen recording wasn’t attached to this post, but if you’re up for it, feel free to share it via a Loom or Google Drive link so I can take a closer look.
To help us dig in a bit more, could you me us know:
  • Is this lag also happening in the browser?
  • Have you seen any memory alerts pop up in the file?
  • When did you first start noticing the slowdowns?
  • Does it happen in one specific file, or across all your files?
  • How often is the issue happening — every time, or off and on?
  • And lastly, have you had a chance to try resetting Figma or restarting to see if that helps?
Thanks for your help!
AnnaRocca
Jun 10, 2025 7:51 PM UTC
this is also happening with me
Cristian_Banu
Jun 10, 2025 9:34 PM UTC
How can I attach a video? It doesn’t allow me to.
It’s the desktop app, I mentioned that in the title. It’s been going on for quite a while, since I started using UI3, but only if the Layers panel would be open. That’s why I always switch to the Assets panel, and rarely use the Layers panel, that’s the workaround I found, and the lag is gone. But a couple of days ago it started being laggy even if the Assets panel is open instead pf the Layers panel. Kight have to do with the constant changes I see in the UI, I get used to something, then BAM, it changes. Maybe performance is tied to these  recent changes.
But it’s very annoying, basically, once I click on an element, it takes almost a second for it to get selected. So if I was to click and drag quickly, the cursor would arrive at the destination long before the element actually starts to change its position because of the dragging.
I have cleared the cache, reset Figma and still the same thing. I am using a single tab btw, I closed all other tabs to see if it’s related to having multiple tabs open.
It happens in all files, always.
Gayani_S
Jun 12, 2025 12:22 PM UTC
Hey ​@Cristian_Banu, thank you for your detailed follow-up!
At the moment, it’s not possible to directly upload a video to the Forum, but you can still share screen recordings by uploading them to Loom or Google Drive and posting the link here.
In the meantime, I’ve already opened a support ticket for you. Your ticket number is #1389092, for reference. Someone from our technical support team will be reaching out to you soon via email. When you get a chance, it would be helpful if you could also share your desktop debug logs with the team. You can find the steps on how to save them here: Download Figma desktop app debug logs.
If it’s easier, feel free to share the screen recording directly via email as well so the team has all the context when investigating.
Thank you again for your patience and let me know if there is anything else I can help with!
Gayani_S
Jun 12, 2025 12:26 PM UTC
Hey ​@AnnaRocca, I’m really sorry to hear you’re running into this too!
To help us better understand what might be causing the lag, could you take a moment to answer the questions I posted above? The more details we have, the better we’ll be able to narrow down what’s going on and get this sorted for you.
Appreciate your help!
