vinay webhopers
Nov 19, 2025 12:07 PM UTC
Why I am seeing this error when opening the prototype?
    Celine_Solution
    Nov 20, 2025 2:29 PM UTC
    Hey ​@vinay webhopers , I checked internally and it looks like this was caused by a recent change on our side, which has now been rolled back.
    If you’re still seeing the issue, please reply directly to you case so our technical quality team can take a closer look and investigate further. Thank you! 🙏🏻
    Update: I see that you’ve confirmed with our support team that the issue has been resolved on your end. I’ve gone ahead and close the topic here. Thank you!
    Nov 19, 2025 2:19 PM UTC
    Hey ​@vinay webhopers , thanks for flagging this, and I’m sorry you’re running into a rendering issue with your prototype.
    This looks like it may be related to an ongoing bug our team is currently investigating, and I’d like our team to take a closer look at it. I was able to locate your case and have escalated it internally so it gets the right visibility. For reference, your case number is #1606784.
    Thanks for your patience while the team takes a closer look. They’ll reach out to you directly through your case 🙏🏼
    vinay webhopers
    Nov 20, 2025 6:40 AM UTC
    Have you found any solution?
    Celine_Solution
