Stefan_Ilijev
May 3, 2025 8:02 AM UTC
Why Figma on Windows is having bad scroll behavior with touchpad?
As of now, I encountered a problem with touchpad behavior on my laptop. The overall problem is that when I try to move with two-finger scroll, it only locks to horizontal or vertical scroll.. but when you try to do a circular movement or diagonal, it doesn’t work.. it only works if you start doing the diagonal/circular movement from the start.
So the overall problem is that movement with trackpad is segmented and it’s not fluid like other systems. This problem is not present in MacOS or Linux versions and I also tried multiple touchpad-s that I have and they all have the same problem.
