godhacker666
May 1, 2026 12:31 AM UTC
why does my messages keep saying failed again and again?
so basiccly I'm making a music website, and I'm currently adding like 200 songs and a patch notes buttons WHICH IS NOTHING FOR FIGMA.. and it keeps saying failed.
    May 1, 2026 6:16 AM UTC
    Hi ​@godhacker666 ,
    I understand you're seeing a "failed" message repeatedly in the AI chat in your Figma Make project.
    I want to make sure I understand your setup — are you trying to attach audio files or other files directly to your prompt? If so, please note there are some limitations:
    • You can attach up to 10 files per prompt
    • The total number of attachments depends on your plan (e.g., Starter plan: 30 attachments)
    For more details, check out: Attach files to a prompt
    If that's not the case, could you let us know if you're seeing a specific error message? This guide lists common error messages and what they mean, which might help: Troubleshoot in Figma Make
    Also, does the issue still occur if you switch to a different AI model? Select an AI model to use in Figma Make
    If none of the above helps, please submit a bug report so our team can take a closer look:
    1. Go to the Support Hub
    2. Type "Report a bug" and Click Start a chat
    3. In the form, please include:
      • A direct URL to your file - View access granted to support-share@figma.com (this won't affect your billing)
      • A screenshot or short video of the issue
      • A brief description of what you were trying to do in Figma Make
    This will help our team visualize and investigate the issue more effectively.
    Thanks!
    ilex04
    May 1, 2026 6:57 AM UTC
    That usually happens when the file gets too heavy or your browser struggles to handle it.
    Try this:
    • Refresh Figma or reopen the file
    • Clear browser cache or switch browser (Chrome works best)
    • Split your design into smaller pages/files instead of putting everything in one
    • Check your internet connection
    If it still fails, it might be a temporary Figma issue give it a bit and try again 👍
    godhacker666
    May 2, 2026 1:57 AM UTC
    yeah I tried that and it still says failed, maybe its a big document?
    adamsmasher
    May 2, 2026 10:19 PM UTC
    Hey ​@godhacker666! Stepping in for ​@Junko3.
    Thanks for trying the solutions provided by ​@Junko3 and ​@ilex04. Since those didn’t seem to resolve the issue for you, I went ahead and created a ticket with our support team (ticket #1881516). Can you reply to that with more information about the problems you’re having, and a link to the file itself. You should also share it with support-share@figma .com with view access. Don’t worry, you won’t be charged.
    You should hear back soon from our team - thank you for your patience!
    godhacker666
    May 4, 2026 2:27 PM UTC
    dont worry I'll try again!
    godhacker666
    May 4, 2026 2:34 PM UTC
    nope, it says: e306add8-8a3a-484e-860c-256214424a08.
    ksn
    May 6, 2026 7:27 PM UTC
    Hey ​@godhacker666 - thanks for your patience. Just checking in to let you know that the support ticket ​@adamsmasher created for you (1881516) was reviewed, and one of our support team members has reached out to you.
    I did let them know about the error message you provided above as well. Please check your email for that reply (also check spam in case you don’t see it).
    godhacker666
    May 6, 2026 10:13 PM UTC
    I so not see it at all.
    May 7, 2026 11:04 AM UTC
    Hey ​@godhacker666 , please check your inbox (and spam folder) directly via your email address: rbxxxx75@gxxxl.xxm, thank you!
