MakePixelsWork
Jul 10, 2026 7:39 AM UTC
Why do AI prompts always add background to transparent images?
When I remove backgrounds from images and then change the image, the AI always adds a background back into it. This is quite annoying. Can this be removed?
Nike logo as example. Prompts show above the image, with results below them. Gray bars are there to show the transparency.
  • Imported a Nike logo on pink background
  • Copied it, and asked the AI to remove the background. Did it perfectly!
  • Copied the transparent image and asked AI to change Nike to Spike. The AI added a background to the image. Why?!
I’m sure a workaround could be to ask the AI to first change it to spike and do the transparency at the end, but its just not logic to see things come back / being reintroduced.
Jaycee Lewis
Jul 10, 2026 10:23 PM UTC
 Hey hey ​@MakePixelsWork 👋 Thanks for the great feedback. I want to dig into this a bit with you.
Question: when you ran the edit step (changing Nike → Spike), were you using Agent on Canvas, or the "Edit with prompt" option?
My test: I took an image (fake png from Google search), ran Figma's Remove Background tool on it (worked perfectly, same as you saw), then ran an edit prompt to change its color with no mention of the background — the background reappeared as solid white. I then ran the same edit again, but explicitly added "keep the background transparent" to the prompt — and that preserved the transparency correctly. Does that sound similar to your steps?
Workaround for now: try adding something like "keep the background transparent" to your edit prompt after removing a background
Talk soon! – Jaycee
MakePixelsWork
Jul 14, 2026 12:02 PM UTC
….does that sound similar to your steps?
Well… almost. I use the Remove background button from the bottom menu and used the prompt from the same menu, but I assume this is the same as using the little Agent star next to active object.
You are running into another problem that I also had: the Agent creates a squared background pattern and assumes this is the transparent layer… but its still an image. It looks as if its an object on a classic Photoshop background pattern, but its not transparent in the sense you can see through it.
Currently the only workaround is to do everything you want on the image, but use the Remove background option as the last step. Then it truly is transparent.
Jaycee Lewis
Jul 14, 2026 7:08 PM UTC
Hey ​@MakePixelsWork 🙌 You rock!
I had a few additional questions to make sure I’m clear from your end:
Is this the root issue? The edit step doesn't inherit/respect the alpha state of its own input. It's not that AI edits sometimes lose transparency at random — it's that the edit step isn't treating "this image already has alpha" as information it should carry forward. Does that match what you're seeing?
Experiencing vs. expecting? Expecting — If the source has alpha, preserve it unless told otherwise. Experiencing — having to either re-run Remove Background after every edit. Is that correct?
Anything else specific to your experience worth flagging? Thank you! — Jaycee
MakePixelsWork
Jul 16, 2026 8:48 AM UTC
Almost always. Every step I take after something is made transparent, the AI either adds a new black or white background and flattens the image, or when I ask it to keep the transparency, it sometimes adds the blocked background pattern, which I assume it thinks is what transparency looks like in tools like Photoshop.
Yes. But since its AI, its interpretation varies. Sometimes it does what you want, sometimes it doesn’t. The only way I can achieve my end goal, is to first do the image edits, and do the Remove background prompt at the very end. This is thus far the only way to get transparency.
A screen-recording of the process has been made available at:
https://go.screenpal.com/watch/cOiDj7nUkPd
Jaycee Lewis
Jul 18, 2026 12:09 AM UTC
Thanks ​@MakePixelsWork 👋 I’m going to open a support ticket for this. And you are correct about my last test getting a fake “checkerboard” background. 🙃 I’ll add the details (ID and subject line) back here so you can find any replies or requests from the team. Thanks again for all the help so far! — Jaycee
Jaycee Lewis
Jul 18, 2026 12:27 AM UTC
Here the ID and subject line — ID 2021707 and Edit Image reintroduces background on already-transparent images. Appreciate you! — Jaycee
