Saige_Fraiha
Feb 16, 2026 8:54 PM UTC
When using wysiwyg shortcuts in component description the main UI design should not change.
  1. Modify a component with multiple variants
  2. Use the “component description” to write a description and select some text to modify.
  3. Use bold, italic, or underline keyboard short cuts within the description. (command + b for example)
  4. Observe that both the selected description text and the actual UI design are modified by this.
  5. Shouldnt it only affect the wysiwyg editor if that’s open?
Heres a quick video of the issue.
