minhyuncho
May 14, 2025 9:46 AM UTC
When copy/ paste, Most Measures disappear.
When copying and pasting, all Measures disappear.
To create a design guide, I create a Measure in the UI built with the component and use the
and copy-pasted it into the component-built UI, all of the Measures disappeared.😰
They also disappeared when I copied and pasted a single component or a section containing components.
I doubt Figma would release a feature without doing a simple QA.
May 22, 2025 6:52 AM UTC
Hi ​@minhyuncho,
If I'm understanding correctly,  adding measurements to a main component, but those measurements aren't appearing in the instances of that component. Is that right?
If so, I've tested this on my end and I'm able to replicate the issue. I'll go ahead and escalate this to our team for them to check out.
Thanks!
minhyuncho
May 23, 2025 8:11 AM UTC
Hi. ​@Junko3
yes… Why can’t replicate the issue…. hmmmm…
Unfortunately, the issue still occurs.
If more users use 'measure' and more issues in this forum... then plz fix it.
May 27, 2025 5:53 AM UTC
Hi ​@minhyuncho,
Just to make sure everything's clear and there's no misunderstanding:
I was able to recreate the issue you are facing as I mentioned in my previous reply👇
I've already created an internal report for our team to investigate this issue, so please rest assured that it's being looked into.
While we can't provide a timeline for a fix just yet, we truly appreciate you bringing this to our attention!
