nikolas grigoriou
Oct 26, 2026 6:16 PM UTC
Wacom pen Pan/Scroll + Command no longer zooms the canvas in Figma Desktop on macOS
Environment
• macOS: 27.0.1 (26A434)
• Figma Desktop: 126.10.13
• Tablet: Wacom Intuos
• Wacom driver: latest version
• Input device: Wacom pen side button assigned to Pan/Scroll in Wacom Center
Description
Until about a week ago, I could zoom in and out of the Figma canvas using this workflow:
1. Hold Command on my Mac keyboard.
2. Press and hold one of the side buttons on my Wacom pen.
3. The pen button is assigned to Pan/Scroll in the Wacom desktop app.
4. Dragging the pen would zoom the Figma canvas in and out.
This no longer works in the Figma Desktop app.
What I’ve tried
• Updated to the latest Wacom driver.
• Reassigned and tested different Wacom pen-button functions, including Pan/Scroll and other navigation options.
• Restarted Figma and the Mac after changing Wacom settings.
• Verified that the same physical key combination works correctly in Figma running in Safari.
Expected behavior
With Command held on the keyboard and the Wacom pen button set to Pan/Scroll, dragging the pen should zoom the Figma canvas in and out, as it did previously and as it still does in Figma in Safari.
Actual behavior
In Figma Desktop, the canvas does not zoom. Depending on the Wacom setting, the input is either ignored or triggers unintended macOS behavior, such as the input-source/language-switch dialog.
Additional notes
Because the exact same Wacom setup and Command + Pan/Scroll combination works in Figma in Safari, this appears to be specific to how the Figma Desktop app handles Wacom-generated scroll/pan events or modifier-key combinations.
Could you please investigate whether a recent Figma Desktop update changed the handling of Wacom scroll input or Command + scroll events?
Thanks—I’d really appreciate any guidance or fix, as this workflow is central to how I navigate Figma with my tablet.
ksn
ksnSolution
Oct 30, 2026 2:04 PM UTC
Hey all! An update:
After discussions with our technical quality and engineering team, the suggested solution is that you roll your drivers back to the previous one Wacom had in production, and reach out to their support team for further assistance. They may be able to help with reviewing the updates to see what may have affected your experience within Figma overall.
While Wacom tablets can often be paired with Figma/Figjam for use, we don’t currently provide official support of it. That, combined with all of your helpful testing, have led us to this conclusion.
Thank you for your patience while I looked into this, and apologies if this causes an inconvenience.
ksn
Oct 26, 2026 8:23 PM UTC
Hey ​@nikolas grigoriou - thank you for joining us on the forum! I understand that the behavior between using your wacom tablet/pencil seem to have changed.
Can you try using Figma in a different browser (if you have one outside of Safari), and see if the behavior persists there too? If it does, it confirms the likelihood of this being limited to the desktop app. I’d like to start there.
Thank you!
nikolas grigoriou
Oct 26, 2026 9:16 PM UTC
Thanks for the reply ​@ksn !
I can confirm that the same applies on Google Chrome, everything works as expected. So, I guess it has to do with the Figma desktop app.
gang
Oct 26, 2026 8:34 PM UTC
having the same issue, and would love to know how to fix...
Pyetro
Oct 27, 2026 10:53 AM UTC
I had problems with Pan/Scroll in Figma layers list right after updating to Wacom Driver 6.4.15-1.
Reverting drivers to 6.4.14-2 solved the Figma issue…
ksn
Oct 27, 2026 2:38 PM UTC
Thanks everyone for reporting. I’m inquiring internally about this now. From what I’m gathering, it’s limited to the desktop app specifically, and it seems tied to Wacom’s recent driver update (thanks ​@Pyetro for providing that info).
At this time, my recommendation for you both ​@nikolas grigoriou ​@gang is to also try reverting back to the former driver to see if things start working as expected again. I will update when I learn more!
EDIT: one suggestion from our engineering team is to try using the Figma beta desktop app with the new driver, if you can do so -- the result here will also be helpful. If you can give that a try, let me know how it goes!
nikolas grigoriou
Oct 27, 2026 4:05 PM UTC
Thanks for the reply! I can confirm that with the latest Figma Beta, the unexpected behaviour is the same as within the latest Figma desktop app ​@ksn.
ksn
ksnSolution
Hey all! An update:
nikolas grigoriou
Nov 2, 2026 6:16 AM UTC
Hey ​@ksn !
Thanks for the update.
After getting in touch with the Wacom support, below are the comments I received.
“Based on your testing, especially the fact that the same Command + Pan/Scroll workflow continues to work in Figma via Safari, this does not appear to be a hardware issue with your tablet. Since the behavior changed after the driver update and is only affecting the Figma Desktop application, it may be related to a compatibility issue between the current Wacom driver and the way the latest Figma Desktop version handles these input events.”
“As a test, you may try rolling back to the previous Wacom driver version that was working correctly and check whether the zoom functionality returns. If it does, that would help isolate the issue. In the meantime, I also recommend continuing your report with Figma, as their desktop application may require further investigation regarding Wacom Pan/Scroll input handling.”
“If the previous driver restores the Command + Pan/Scroll zoom behavior in Figma Desktop, that would indicate a compatibility change between the current driver and how Figma Desktop is processing those inputs.”
“Since you've verified that rolling back to the previous driver immediately restores the expected behavior, this strongly indicates a compatibility issue introduced with the newer driver rather than a hardware problem with your PTH-460 or a change in your tablet settings.”
I hope that the issue is resolved for everyone, soon enough.
Thanks!
Pyetro
Nov 13, 2026 7:14 PM UTC
I think I found a temporary workaround to enable to use the latest drivers
**Update: found the cause, and a fix that works for me.**
I compared the installers of 6.4.14-2 (last working) and 6.4.15-1 / 6.4.15-2 (broken).
**Where the bug is**
The driver has a per-app gesture file called `AppGestures.xml`. In 6.4.14-2 it has no entry for Figma, so Figma uses the generic entry, where the pen-button pan setting (`GrabberHand`) is `usescrollpan`: the driver sends scroll events. 6.4.15-1 added a Figma entry at the end of the file:
    <!-- ========== Figma ===== -->
    <ArrayElement type="map">
        <identifier type="string">com.figma.Desktop </identifier>
        <GrabberHand type="map">
            <input type="string">mousebutton</input>
            <mousebutton type="string">left</mousebutton>
            <modifiers type="string">space</modifiers>
        </GrabberHand>
    </ArrayElement>
With that, the pen button sends space + left-button drag in Figma instead of scroll events. That pans the canvas, but the Layers and Pages panels don't respond to it. The file is identical in 6.4.15-1 and 6.4.15-2.
It isn't only Figma: 6.4.15-1 made the same switch to left mouse button + space in 27 other app entries, including Sketch, Clip Studio Paint, Corel Painter, After Effects, Photoshop Elements, Acrobat/Reader, ArtRage, SketchBook, OmniGraffle and Capture One. Those entries used the space key before, so pen-button panning may behave differently there too.
**How to fix it**
Delete that Figma block (comment line included) from both copies of the file, which are identical, then restart the Mac:
    /Applications/Wacom Tablet.localized/.Tablet/WacomTabletDriver.app/Contents/Resources/AppGestures.xml
    /Applications/Wacom Tablet.localized/.Tablet/WacomTouchDriver.app/Contents/Resources/AppGestures.xml
The files belong to root, so you need admin rights to edit them. Keep a copy of the original first. If you didn't, reinstalling the driver restores it.
Figma then behaves as it did in 6.4.14-2: the pen button scrolls everywhere, panels included. On the canvas it pans by scrolling, without the grab hand; space + drag still gives the normal hand tool.
**Adobe apps (optional)**
In Photoshop, Illustrator and InDesign the pen button has never scrolled the Layers panel, in 6.4.14-2 either: in neither version does their entry use scroll events. 6.4.15-1 only changed the pan setting for Photoshop and Illustrator, from the space key (or nothing, for Illustrator 17 and later) to left mouse button + space. InDesign's entry didn't change.
If you want the pen button to scroll their panels, replace the contents of their `GrabberHand` block with the generic one:
        <input type="string">usescrollpan</input>
        <amount type="double">1</amount>
    </GrabberHand>
Illustrator has two version sets in the file and both need it. InDesign has no `GrabberHand` block, so I added one. Don't delete these entries, they also hold the zoom settings. The trade-off: canvas panning with the pen button loses the grab hand and its speed is off (slow in Photoshop, fast in Illustrator), so I use space + drag on the canvas there.
**Caveats**
- Tested on one machine: Wacom Intuos Pro M (PTH-660), macOS 26.7.3, Apple Silicon, driver 6.4.15-2.
- The file is inside signed app bundles. After editing, `codesign --verify` reports "a sealed resource is missing or invalid" for both driver apps. The driver still works normally for me after a restart, but I can't promise that on other macOS versions.
- Updating or reinstalling the driver overwrites the edit and puts the original file back.
- I haven't looked at the Windows driver.
- At your own risk. The real fix has to come from Wacom, so please report it to them too.
