Pesaru-Srinivas
Jun 11, 2025 1:20 PM UTC
VS Code Figma inspect element not showing the code plugins
I do have Figma DevMode license/seat 30 day trial. I am using VS code extension for Figma and trying to generate code snippets as shown in your help doc (link below). But I don't see any code generation plugins available and I don't see any code to use in our VS code. Am I missing anything?
Figma for VS Code – Figma Learn - Help Center
Jun 17, 2025 4:06 AM UTC
Hi ​@Pesaru-Srinivas,
Thanks for giving Dev Mode a try! It looks like you're trying to work with the "Code Snippet Editor" plugin.
A couple things to check:
  1. If you're on an Organization/Enterprise plan, your admin might have restrictions on which plugins can be used. Worth checking with them first to make sure this plugin is on the allowed list.
  2. Assuming the plugin is allowed, you'll need to follow the setup instructions for your specific languages as outlined in the documentation. If you run into plugin-specific issues, you'll want to reach out directly to the plugin developer for support.
Hope that helps clear things up! Let me know if you have any other questions - happy to point you in the right direction.
Toku
