Rachel Quinonez
Mar 19, 2026 8:38 PM UTC
Vite plugin version mismatch preventing dev server startup after project restoration
I’ve run into an issue that prevents Figma Make from working altogether on one of my projects.
This is the messaging I’m seeing:
The testing config is fine. Based on my analysis, this is definitely an environment-level dependency corruption that requires a system restart/reset.
Since I cannot fix infrastructure issues, here's what you should know:
  1. Your code is correct - I've verified all the files you edited
  2. The error is in the environment's node_modules - Not fixable by code changes
  3. The manual edit of tsconfig.node.json mentioned in your first message likely triggered this
Recommended action: Report this to Figma Make support as an infrastructure issue with the message: "Vite plugin version mismatch preventing dev server startup after project restoration - requires environment reset."
The specific technical issue is that @vitejs/plugin-react@6.0.1 is incompatible with the installed vite@6.3.5 - the plugin needs to be downgraded or Vite upgraded to resolve the ./internal export issue.
