Ben_Decker
May 25, 2021 4:18 PM UTC
Visibility and Connector Issue When Pasting from FigJam into Figma and into Frames and Components
1. Describe the bug/issue you’re running into?
When I copy and paste a flow from FigJam into Figma, there is unexpected behavior whether flows show up or stay connected inside of Frames and Components. It seems the main issue is that connectors don’t stay connected inside of components, and FigJam flow elements don’t want to be placed inside of components.
It also seems like Figma doesn’t know what to do with connectors that are not linked to a node on a Frame.
My example shows many frames that have multiple connectors because of multiple touchpoints and paths on each screen.
2. Are you able to consistently reproduce it? If so what are the steps?
Yes.
Trying to bring flow into Figma Frame
  1. Copy flow from FigJam
  2. Paste into Figma on canvas.
  3. Try to drag into frame. SUCCESS!
  4. Either select all elements and create a Frame from selection, or select destination frame and then paste into selection. SUCCESS!
Trying to bring flows into a Figma Component
  3. Try to drag into a component. Elements don’t nest into Component Frame by dragging.
  4. Either select all elements and create a Frame from selection, or drag it into another frame, then drag or paste that frame into component.
Fail…
Most of the elements and connectors come in fine, but many connectors don’t end up in the frame, AND you cannot move the frame with the flow around inside of the component or the connectors get out of alignment if they are not hooked up to a frame node.
AND there’s no way to connect these connectors to new nodes inside of these frames or components, because they seem to jump to the nearest node of the highest parent frame. And there’s no flexibility to try and expand or change a connector into a simple vector line.
3. Share a screenshot, recording, console log, link to the file, etc.
Figma – 25 May 21
4. Is the issue only happening in desktop app or a specific browser , or both?
I’ve only tested in Figma desktop app.
5. What OS/version and/or browser/version are you using?
MacOS Catalina 10.15.7
Mazvydas_Bartkevicius
Jul 25, 2022 1:04 PM UTC
Why connector is not part of Figma files too? It breaks the whole experience…
be_jeffm
Nov 3, 2023 2:59 AM UTC
This is still not solved and it’s 2023 already
David_Pindrys
Jan 11, 2024 10:19 PM UTC
And here we are in 2024 :\
emphasent
Jan 19, 2024 3:18 PM UTC
This is really troubling. I do a lot of flowcharts for scientific papers for which Design is much better suited than FigJam. Every time I move a frame around, the connectors immediately detach and move to the main page. i can manually move them back into the frame but doing this repetitively causes a lot of annoyance.
be_jeffm
Aug 6, 2024 3:18 AM UTC
Yeah it’s 2024 and it’s still not fixed!!!
be_jeffm
Aug 8, 2024 5:38 PM UTC
I wish they should just put a connector option on the Line tool at the bottom…
