Paul_Brouwer1
Variable search broken
I noticed recently that the variable search suggestion is quite broken when I enter my queries. Below is a screenshot of me writing my query to filter down my results. But you can see the results don’t filter correctly.
This as been the case for a while now.
Julia57
April 15, 2026
Ran into this problem this week as well. Typing into the box seems to do something because the results list changes, but it doesn’t seem to be filtering any of the results based on the query.
Cammy Hogg
When searching for a colour style, results for similar colours appear above the exact match.
For example, I want to apply the root colour “Teal/600”. Above the exact match appears the similar looking “Blue/600”. It’s therefore more clicks/key presses to navigate to the exact match, whereas previously I could simply click the ‘Enter’ key.
Weighting should be changed so that the exact match always appears first.
Sayful_Islam_Shakib1
The new color selection color picker is broken please fix it.
Hey All, thanks for flagging this issue!
I completely understand how variable search not working as expected must be slowing down your workflow. I’ve flagged this over to our team to investigate and work towards a fix. I’ll provide an update as soon as I hear back from the team.
We appreciate your patience and understanding in the meantime.
Hi ​@Sayful_Islam_Shakib1, thanks for flagging!
I’ve merged your topic with another similar one in the community regarding the same issue. Again, our team is already proactively investigating, and I’ll provide an update from the team as soon as I hear more.
Paul_Brouwer1
​@djv What’s the status of this?
Hi ​@Paul_Brouwer1, thanks for following up!
The team hasn’t been successful at fixing the root cause of the issue, so they just recently decided to roll back the change to the library modal search experience.
When was the last time you refreshed your tabs or updated your Figma desktop app, you should now see the same results and ordering as before. The team has no plans to push the version that caused variable search to break in the first place, until they have a proper solution.
Paul_Brouwer1
​@djv Should I restart or update figma to see these changes?
Hi ​@Paul_Brouwer1, sorry for the delayed reply!
Simply refreshing your tabs should have reverted the behavior, but let me know if you run into any further issues.
Babarogic
This issue is still persistent… very annoying
