Shravani Gudhate
Oct 25, 2026 10:19 PM UTC
Urgent: Original Figma Make project not loading — possible project recovery
Hello Figma Support,
I am unable to access my original Figma Make project, which I worked on extensively for approximately 18 days.
When I open the original project URL, Figma Make displays a new blank chat asking me to enter the first prompt instead of loading my existing project and its previous work.
This project contains important UI design work for my final-year engineering project, SDA. I am concerned about losing the original screens and previous prompts.
Original project URL: https://www.figma.com/make/1SyCYD24RlYTZRQlGEsgE9/Untitled?p=f&t=TRgdz40qd5yMCu6u-0
Figma account email: [Redacted by moderator - 2026/10/25]
name : Build SDA Dashboard
Could you please investigate whether the original file and its previous work are still recoverable, and help restore access if possible?
I have not intentionally deleted the project. I would appreciate guidance before I attempt to rebuild it.
Thank you.
Celine_Solution
Oct 26, 2026 10:02 AM UTC
Hey ​@Shravani Gudhate , Celine from the Figma Community Support team here. I’m sorry to hear your original project is opening as a blank chat, especially after the time you’ve spent on your final-year project!
That behavior alone doesn’t confirm that your previous work has been deleted. I’ve created a support ticket on your behalf so our team can examine the original file and see what happens there. For reference, your case number is 2222252 sent to the email address you have shared here.
Please continue the conversation directly via your support case and confirm you’re signed in to the same Figma account you used to build the project. Please also grant Can View access to support-share@figma.com if you still have access to this file. The support team will follow up privately by email for a screenshot of what you see and when you last successfully accessed your work. This will help us investigate, thank you!
Update: The support agent has replied to you. It seems that this file is linked to another email address, can you please check on your side if you have another Figma account? And please continue the conversation directly via your support case for investigation.
As all requests have been addressed here, I am closing the thread, thank you!
Celine_Solution
Ewen
Oct 26, 2026 11:15 AM UTC
Bonjour ​​@Celine_,
Je rencontre exactement le même problème depuis la semaine dernière, mon projet Figma Make s’ouvre vide alors que j’ai un travail très important.
Pouvez-vous retrouver mon projet svp ?
Cordialement,
Oct 26, 2026 11:39 AM UTC
Bonjour Ewen, je suis désolée d’apprendre que vous rencontrez également ce problème avec votre projet Figma Make!
J’ai retrouvé votre demande auprès du support envoyé avec votre adresse mail: hxxxe@rexxxs.xxm. J’ai ajouté une note de suivi pour lui donner davantage de visibilité. Notre équipe pourra examiner votre fichier et vérifier les possibilités de récupération. (Pour référence, votre numéro de dossier est 2212718.)
Un membre de notre équipe vous répondra prochainement par email pour vous guider dans les prochaines étapes. Merci pour votre patience !
Update: Notre équipe support vous a répondu par email en vous indiquant les prochaines étapes. Pensez à consulter votre boîte de réception et à poursuivre l’échange directement dans ce fil d’emails afin qu’elle puisse examiner votre situation plus en détail. Merci !
