Michel Kerkmeester
Jan 15, 2026 11:32 AM UTC
URGENT: Critical Regression in Component Boolean Properties (Breaking Production Files)
Team,
I am writing to report a high-priority issue regarding component property inheritance that is currently breaking multiple production design systems and mockups across our organization.
The Issue:
Boolean properties (specifically visibility toggles for icons/elements) that were previously set to "False" in child instances have spontaneously reverted to "True" across thousands of instances. Even after manually fixing the errors, the bug re-appears after DS instance update.
Technical Observations:
Scope:
This is affecting instances across multiple files linked to a central library, despite no changes being made to the main components.
Impact:
All our flows are currently visually broken. This issue is costing us thousands of dollars in lost hours.
Request:
Please investigate if there was a recent deployment affecting the property override logic or the rendering engine. We need an immediate fix or a rollback of the recent update to restore the integrity of our design files
Celine_Solution
Jan 21, 2026 12:16 AM UTC
Hi again everyone, we've identified a potentially related issue and pushed out a fix.
Can you please reload your tabs/files and let us know if you continue to see the issue happening? Thank you!
Jan 23, 2026 12:44 PM UTC
Glad it’s working now, thanks for confirming!
