Bauke_Schildt
Aug 6, 2026 4:08 PM UTC
Unexpected behaviour: Variables not updating in nested variants.
I have a button (Component A) that uses variables in a nested component (Component B).
Padding and Min-height in the nested component are variables, because we have more than one brand and they use different paddings and button heights
The button has 36 variants; 3 Types (Primary, Secondary, Tertiary), 4 States (default/hover/pressed/disabled) e 3 surfaces (default/inverse/brand).
Issue: When I change the Variant of the Nested Component, it completely ignores the variables used in the variant:
This only happens when it’s a nested component. Otherwise it works as expected.
I really don’t want to add variants for every size (XXL, XL, LG, MD, XS & XXS) , because that would be 216 variants to keep track of, instead of 36.
Jaycee Lewis
Jaycee LewisSolution
Aug 10, 2026 10:47 PM UTC
Hi, ​@Bauke_Schildt 👋 Thank you very much for your help so far. I opened a support ticket for you. The ID is 2064043 and the subject line is Variable-bound padding and min-height retain the previous variant's values when switching the variant of a nested instance. Please keep an eye on your email inbox (and your spam folder too) for the ticket and any replies from our team. Best! — Jaycee
Jaycee Lewis
Aug 7, 2026 8:08 PM UTC
Hey ​@Bauke_Schildt 👋 Thanks for the post and for including your details. I have a few questions to help narrow things down:
  • Could you try building a brand-new parent component in the same file, nest a fresh instance of the button inside it, and cycle through the Size property there? If a fresh parent behaves correctly while your existing one doesn't, that’s a useful clue
  • On a nested instance showing the wrong padding, does right-click > Reset all changes bring it back to the values you'd expect for that size?
  • Are padding and min-height in each size variant bound to separate variables (one per size), or to the same variable resolving through different modes? If it's the latter, can you check if a mode has been set explicitly on the instance or on a parent frame?
Thank you! – Jaycee
Bauke_Schildt
Aug 10, 2026 11:03 AM UTC
Did that first, to try and figure out why it wasn’t working. The unexpected behavior only starts when I  assign variables to the padding and height values. If they are normal values, they update as expected.
If I change the nested instance from XL to LG and then reset the nested instance it goes back to the original size (XL), so that doesn’t work...
They’re bound to different variables.
Simplified: button/padding/xl, button/padding/lg, button/padding/md; set to 32, 24, 16, respectively.
And min-height is set to button/size/xl, button/size/lg, button/size/md; set to 56, 48, 40, respectively.
Jaycee Lewis
