VC_team
Jun 8, 2026 7:23 AM UTC
Unexpected Amount Occurred
5월 카드 결제 내역을 확인했는데 예상치 못한 금액이 결제되었습니다. 결제일은 5월 8일이며, (redacted by the moderator due to PII) 계정으로 전액 결제(full sheet)로 설정되어 있습니다. 해당 계정은 전액 결제 권한을 사용한 적이 없으며, 결제 내역이 전액 결제로 설정된 이유를 알 수 없습니다. 가능하면 (redacted by the moderator due to PII) 계정에 대한 결제만 취소해 주시기 바랍니다. 빠른 답변 부탁드리며, 이메일로 회신해 주실 경우 (redacted by the moderator due to PII) 로 보내주시면 감사하겠습니다.
Celine_Solution
Jun 8, 2026 9:00 AM UTC
Hi ​@VC_team , Celine from the Community Support at Figma here, thanks for following up. I don't speak Korean, so I hope it's okay if I reply in English.
I understand that dexxer@inxxxd.co.kr appears to have been assigned a Full seat unintentionally, resulting in an unexpected charge, and that you'd like the charge to be canceled.
I've removed the email addresses from your post to help protect your privacy.
I can see that you've already contacted our Support team using yxxxi@inxxxd.co.kr, and I've gone ahead and added a follow-up note to your existing case for visibility.
Our support team will be able to review the seat assignment and billing details in full and discuss any available options with you directly. Please keep an eye on your inbox for their response. Thanks for your patience!
Quick update: I can see that our support team has solved your issue! 🙌🏻
Please note, to help avoid similar charges in the future, we recommend changing your seat approval settings to require manual approval before paid seats are assigned. This gives you more control over seat upgrades and helps prevent unexpected billing.
 I’ll go ahead and closed the topic here, thank you!
Celine_Solution
