Cristofaro_DiNoto
Feb 19, 2025 4:49 PM UTC
Underline Superscript Marks Doesn't Work
When underlining a text button, the registration mark or other marks don’t underline properly. The new offset feature also doesn’t fix this issue. Is there a way to underline the baseline of the text layer instead of the characters?
ScottDaniels
Mar 11, 2025 1:41 PM UTC
​@Cristofaro_DiNoto
I found a hacky solution for this by simply using strike-thru instead. Superscript the content, then apply strike-thru. This works as a visible solve but more work for designers to explain it to developers who refer to specs in DevMode.
  • The Figma team should fix the offset to work for actual superscripted links.
  • They should also make it so we can apply effects like superscript to text with styles applied without detaching.
