Igor Goncharov
May 25, 2026 5:21 AM UTC
Unable to publish plugin - Please fill out required fields and correct any errors
I’m trying to publish a plugin.
On the Step #2 - Choose some images - I populated everything and still see “Please fill out required fields and correct any errors”.
Could you please suggest a solution?
Celyn_L
May 25, 2026 6:18 AM UTC
Hi ​@Igor Goncharov, Celyn from Figma Community Support here.
Thanks for flagging this and also for sharing the screenshot, that’s really helpful.
I understand that you’re trying to publish a plugin and are seeing the “Please fill out required fields and correct any errors” message during Step #2, even after populating everything that is required. That definitely doesn’t sound like the expected behavior here.
I’ve gone ahead and created a support ticket for you so the team can investigate this more closely - your case number is #1924322.
Someone will follow up with you directly via your ticket soon, so please keep an eye on your inbox.
Appreciate your patience while we look into this.
