Tyler Yin
Mar 27, 2026 9:28 AM UTC
Unable to publish Figma plugin. INVALID_SUPPORT_CONTACT with a valid email
Trying to publish my Figma plugin, but getting an error saying “Please fill out required fields and correct any errors”.
On the frontend, I don’t see any fields highlighted with errors.
When inspecting console logs, I see a ton of warnings being thrown for INVALID_SUPPORT_CONTACT even though the support contact I’ve entered is a valid email address. I’ve also tried a website url, a different email address, and nothing works.
Please help. Don’t know what else to do/try here.
Celine_Solution
Mar 31, 2026 9:30 AM UTC
Hi everyone, thanks so much for your patience!
Our team has rolled out a fix. Pease try publishing your plugin again and let us know if everything is working on your end. Thanks!
William_Mincher1
Mar 31, 2026 8:53 AM UTC
I have the same issue.
The file shows an error toast stating “Failed to load fields”
Failed to load fields toast with Retry button
This leads me to believe that there are required input fields that are failing to load in the Publish Plugin wizard.
As they don’t load then they can’t be completed which prevents the plugin from being published.
The developer console throws the following error:
vendor-core-83c17265f2588e9e.min.js.br:54 Unhandled exception in CocreatorsField.fetchInitialValue: TypeError: Cannot read properties of null (reading 'accepted')
    at Object.fetchInitialValue (4602-0363326c5cdb8dac.min.js.br:78:79829)
    at 4602-0363326c5cdb8dac.min.js.br:78:7495
    at 4602-0363326c5cdb8dac.min.js.br:78:7851
    at aB (vendor-core-83c17265f2588e9e.min.js.br:11:83980)
    at oD (vendor-core-83c17265f2588e9e.min.js.br:11:112973)
    at vendor-core-83c17265f2588e9e.min.js.br:11:111359
    at oB (vendor-core-83c17265f2588e9e.min.js.br:11:111425)
    at oL (vendor-core-83c17265f2588e9e.min.js.br:11:96091)
    at f5 (vendor-core-83c17265f2588e9e.min.js.br:11:44783)
    at vendor-core-83c17265f2588e9e.min.js.br:11:93469
Celine_Solution
da.assets
Mar 31, 2026 10:59 AM UTC
​@Celine_ The issue has been resolved for me. Thank you.
Tyler Yin
Tyler YinAuthor
Mar 31, 2026 10:33 PM UTC
Problem was resolved for me as well. Thanks!
Apr 1, 2026 9:47 AM UTC
Thanks everyone for confirming! Glad to hear it’s working now.
I’ve gone ahead and marked as solved the topic here!
Tom Reem
Apr 7, 2026 11:56 PM UTC
Hey ​@junhaosh, ​@Afovea, and ​@da.assets — I touched base with our Product Support team and this issue has been resolved. Thanks to each of you for reporting this and for your patience while the team worked through a fix.
I've merged your posts into a single thread where others experienced the same issue, so everything is tracked in one place. If anything else comes up with publishing, don't hesitate to reach out.
[Moderator note: This post was merged from Can't publish plugin due to missing community publisher into Unable to publish Figma plugin. INVALID_SUPPORT_CONTACT with a valid email on 07-Apr-2026.]
Nathan_Thomassin
Apr 9, 2026 7:21 AM UTC
Edited this message because I mismatched the topic; I read Figma kit instead of Figma plugin.
