cmouchet
Feb 9, 2026 10:07 PM UTC
Unable to publish Figma plugin
Hi there,
I’m unable to publish a new version of the pligin this evening. The error only shows in the console, but I can see that the Author (Share As) section is empty, there’s no way for me to edit this.
validation error INVALID_AUTHOR
vendor-core-26236cac…ecfa60.min.js.br:54 Error(s) from AuthorField.validate:
  1. [{…}]
    1. 0:
      1. data:
        1. currentValue: {user_id: '1538088927895590002'}
        2. [[Prototype]]: Object
      2. key: “INVALID_AUTHOR"
      3. type: "validation"
Can you advise?
Celine_Solution
Feb 10, 2026 1:52 PM UTC
Hey everyone again, our engineering team has pushed a fix!
Please refresh your tab and try publishing again. Feel free to let us know if you’re still running into issues. Thank you
Mar 30, 2026 4:10 PM UTC
Hey ​@Henoch Vitureira , thank you for flagging this!
Can you also confirm if you see any similar error than this ongoing Forum topic?
Our team is currently investigating it. I’d also recommend reaching out directly to our support team so we can take a closer look at your case.
To dot that, please go to the Support Hub / Click Start a chat / Type “Report a bug”
Please include in the form:
  • The URL of the impacted file and shared with support-share@figma.com and grant "Can View" access
  • Attach a screenshot/ video recording when you encounter the error message
    This will help us investigate further, thank you!
Henoch Vitureira
Mar 30, 2026 4:16 PM UTC
​@Celine_ not that error,
This is blocking me from releasing a plugin to my company….
In the console I see:
Error(s) from AuthorField.validate: [{…}]0: {type: 'validation', key: 'INVALID_AUTHOR', data: {…}}length: 1[[Prototype]]: Array(0)
(anonymous) @ vendor-core-83c17265f2588e9e.min.js.br:54
(anonymous) @ 3117-c1e2355d0c9ab775.min.js.br:78
await in (anonymous)
aB @ vendor-core-83c17265f2588e9e.min.js.br:11
oD @ vendor-core-83c17265f2588e9e.min.js.br:11
(anonymous) @ vendor-core-83c17265f2588e9e.min.js.br:11
S @ vendor-core-83c17265f2588e9e.min.js.br:54
O @ vendor-core-83c17265f2588e9e.min.js.br:54
vendor-core-83c17265f2588e9e.min.js.br:54 Unhandled exception in CocreatorsField.fetchInitialValue: TypeError: Cannot read properties of null (reading 'accepted')
    at Object.fetchInitialValue (3117-c1e2355d0c9ab775.min.js.br:78:79692)
    at 3117-c1e2355d0c9ab775.min.js.br:78:7329
    at 3117-c1e2355d0c9ab775.min.js.br:78:7685
    at aB (vendor-core-83c17265f2588e9e.min.js.br:11:83980)
    at oD (vendor-core-83c17265f2588e9e.min.js.br:11:112973)
    at oL (vendor-core-83c17265f2588e9e.min.js.br:11:95829)
    at f5 (vendor-core-83c17265f2588e9e.min.js.br:11:44783)
    at vendor-core-83c17265f2588e9e.min.js.br:11:111419
    at oB (vendor-core-83c17265f2588e9e.min.js.br:11:111425)
    at oE (vendor-core-83c17265f2588e9e.min.js.br:11:94832)
    at vendor-core-83c17265f2588e9e.min.js.br:54:4183
    at S (vendor-core-83c17265f2588e9e.min.js.br:54:1353)
    at MessagePort.O (vendor-core-83c17265f2588e9e.min.js.br:54:1874)
at vendor-core-83c17265f2588e9e.min.js.br:11:111359
at oL (vendor-core-83c17265f2588e9e.min.js.br:11:96091)
at vendor-core-83c17265f2588e9e.min.js.br:11:93469
o.JZ.<computed> @ vendor-64356ad6c6bbf515.min.js.br:3
oB @ vendor-core-83c17265f2588e9e.min.js.br:11
oL @ vendor-core-83c17265f2588e9e.min.js.br:11
f5 @ vendor-core-83c17265f2588e9e.min.js.br:11
requestAnimationFrame
(anonymous) @ vendor-core-83c17265f2588e9e.min.js.br:63
gZ @ 3117-c1e2355d0c9ab775.min.js.br:183
s @ 3117-c1e2355d0c9ab775.min.js.br:348
(anonymous) @ 3117-c1e2355d0c9ab775.min.js.br:1362
dispatch @ 3117-c1e2355d0c9ab775.min.js.br:1362
(anonymous) @ 3117-c1e2355d0c9ab775.min.js.br:183
(anonymous) @ 3117-c1e2355d0c9ab775.min.js.br:967
(anonymous) @ figma_app-353b870bcffa935a.min.js.br:47
(anonymous) @ 3117-c1e2355d0c9ab775.min.js.br:162
(anonymous) @ vendor-core-83c17265f2588e9e.min.js.br:46
(anonymous) @ 3117-c1e2355d0c9ab775.min.js.br:1222
(anonymous) @ figma_app-353b870bcffa935a.min.js.br:233
ez @ vendor-core-83c17265f2588e9e.min.js.br:11
eq @ vendor-core-83c17265f2588e9e.min.js.br:11
fi @ vendor-core-83c17265f2588e9e.min.js.br:11
ff @ vendor-core-83c17265f2588e9e.min.js.br:11
oP @ vendor-core-83c17265f2588e9e.min.js.br:11
eR @ vendor-core-83c17265f2588e9e.min.js.br:11
fl @ vendor-core-83c17265f2588e9e.min.js.br:11
nz @ vendor-core-83c17265f2588e9e.min.js.br:11
nI @ vendor-core-83c17265f2588e9e.min.js.br:11
u @ vendor-core-83c17265f2588e9e.min.js.br:54
oE @ vendor-core-83c17265f2588e9e.min.js.br:11
at vendor-core-83c17265f2588e9e.min.js.br:11:107548
Henoch Vitureira
Mar 30, 2026 4:19 PM UTC
​@Celine_ I see the error: {type: 'validation', key: 'INVALID_AUTHOR', data: {…}}l
I created a post. its awaiting moderation.
This is blocking me from releasing a plugin within my company
Mar 30, 2026 4:32 PM UTC
Thank you for flagging it! I’ve just approved your post.
Appreciate the details, this seems to be related to another issue. Could you please submit a bug report through the  Support Hub as mentioned earlier? The team will be able to investigate your specific case more closely. Thanks 🙏🏼
Update: I can see on our end that you’re now able to publish your plugin again, glad to hear that! Our team has rolled out a fix for the issue you were experiencing.
For others running into the same problem, please try publishing your plugin again. Thanks!
